Started the z06 up last night and backed it out of the garage. I could tell it was missing. Pulled back in and pulled the valve covers to check the springs. Cylinder #1 intake rocker arm was loose. The bolt hole has been stripped.
I assume that it can be helicoiled (sp). Anyone know what size of helicoil I need?
Has anyone else experienced this?
Is this a stock valve train, or has work been done i.e. heads, springs, rockers, etc. ?
Heads and rockers are stock. Camshaft and springs were installed by 21st Century Muscle Cars before I bought the car. Camshaft specs are 224/224 .568"/.568".
Those bolt holes don't strip themselves. Not sure if the head/cam place caused it or they weren't torqued properly. You'll need to see a machine shop now for the helicoil and sizes and it might be needed to remove the head. Make some phone calls to machine shops.
Most likely overtorqued, or the installer torque down the rockers on an open valve. Below is the cylinder head thread repair. I can email you the whole engine thread repair section if you want it.
