Lowering C5 Question!!!
Old May 19, 2010 | 08:01 PM
jpizzlemtg's Avatar
jpizzlemtg
Default Lowering C5 Question!!!
Ok everyone so I lowered my C5 all the way on stock bolts in front with bushings and am sitting at 26.75 and in the rear I lowered all the way to 3 threads suggested by other members for less bottoming out and am sitting at 27.75
Front- 26.75
Rear- 27.75
What I want to know though is talking to a lot of other corvette owners that have gone lower they say that is is better for handling being slammed I know mainly it is for looks but is this true?
Also many of the people I have talked to are doing 7" rear bolts no bushings and front bolts no bushings or no front bolts.
What I want to know in this regard is over big holes right now I can barely hear the bottoming out of shock but if I go to that extreme how noticable will it be? will it drive me mad ?
Also eventually we are talking atleast a year I will buy pfdat coilovers to calm my slammed emotions and have good ride quality but if I do this what do the lowering bolts need to be set at? or do they not matter after coilovers are installed thx guys.
Old May 19, 2010 | 08:13 PM
Dennis Wilson's Avatar
Dennis Wilson
Wont matter, with coilovers the stock springs & bolts will be gone. I cut bushings both ends & sits 26" front & 27" rear.
Old May 19, 2010 | 09:09 PM
jpizzlemtg's Avatar
jpizzlemtg
How bad is your ride though now?
Old May 19, 2010 | 09:14 PM
ipuig's Avatar
ipuig
St. Jude Donor '09
No.
Old May 20, 2010 | 06:38 PM
jpizzlemtg's Avatar
jpizzlemtg
bump.
Old May 20, 2010 | 08:45 PM
socalman's Avatar
socalman
St. Jude Donor '10
It will kick your ars if you go much lower. 7" bolts with all the bushings will drop the rear near 26" right at the tire line, so you don't need to do anything with the rear bushings. Problem with 7" bolts, is it does not graduate from where you are now- 7" bolts with nights full on drops the car with no going back to something in the middle. Use 6" bolts, you'll have more play. You can always then cut away some of the rear ribs if you want lower.
The front bushings, you can cut them (leave 1/8" for rubber support) or remove them, either way, you can always go back up when you decide you hate the ride.
And No, angle of the A arms etc. lowering much more than 1/2" is NOT better for handling.
Old May 20, 2010 | 09:15 PM
Dennis Wilson
Ride is good. IMO.
Old May 22, 2010 | 03:18 PM
Tom Porter's Avatar
Tom Porter
8" bolts in rear and no bolts in front.
Old May 22, 2010 | 08:42 PM
edusmc1's Avatar
edusmc1
Default C5 Lowering
Originally Posted by Dennis Wilson
Ride is good. IMO.
Did you cut any of the bushing to get to 26.75/ 27.75
Old May 23, 2010 | 12:41 AM
Dennis Wilson
I`m at 26/27 cut bushings both ends stock bolts. I think you might get 26.75/27.75 without cutting.
Old May 23, 2010 | 12:47 AM
thechosenone's Avatar
thechosenone
I just lowered mine as well on stock bolts, but I didn't cut the bushings on the front, and for the rear I did the same as you 3 threads showing left.
Old May 23, 2010 | 01:56 AM
jmoody66's Avatar
jmoody66
Just a suggestion.....get u some bilstein sport shocks and the ride will be even better. They are designed for lowered cars and very inexpensive. You can usually find low mileage used ones for 250 or less here on the forum.
Old May 23, 2010 | 02:53 AM
thechosenone
Or some C6 Z06's Shocks as well... epically if you like that stiffer ride .
Old May 23, 2010 | 04:23 AM
jpizzlemtg's Avatar
jpizzlemtg
yes I got 26.75/27.75 without cutting. and I have 3 threads showing on rear I will probobly put the rear at 1 thread this next weekend though when i do new rotors because I do not feel bumps much right now and 2 threads will only get me to about 27.5 in rear
Old May 25, 2010 | 07:50 AM
deadcafe's Avatar
deadcafe
Hey bro I am planning on ordering the bolts for mine front and rear. in the rear at the top of the bolt I have 3 threads showing,,with the 19" rear C6Z rims and tires I still sit approximately 2 inches off the tire, up front it is more like 3. when I am under the car at the passanger tire am I going to turn the bolt like I am tightening it or the opposit?
It is a 2000FRC with the Z51 suspension. Just seems like I am missing something. Is there a picture how to floating around somewhere?
Old May 25, 2010 | 08:34 AM
Z06 Pack's Avatar
Z06 Pack
Just a suggestion.....get u some bilstein sport shocks and the ride will be even better. They are designed for lowered cars. .
This is NOT true. They are not shorter and they are not designed for lowered cars.
Old May 25, 2010 | 08:57 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
you will end up ruining your shocks as they bottom out and split the rubber bumpers on top.. Once your A-arm is not parallel with the ground you are changing the geometry and you lose handling.
To Lowering C5 Question!!!
Old May 25, 2010 | 09:16 AM
j84buick's Avatar
j84buick
Originally Posted by John Shiels
....Once your A-arm is not parallel with the ground you are changing the geometry and you lose handling.
That is exactly what my tuner told me when I had my car was in his shop this month. He told me I was too low and that the control arm was in a position where my geometry was messed up and my handling will be worse for it. I went a little higher in the rear so it is parallel.
Old May 25, 2010 | 11:20 AM
socalman's Avatar
socalman
St. Jude Donor '10
Pick up 6" grade 8 bolts from local True Value, read the post noted at bottom, has pictures of rear and front
post below shows it
I've done a ton of research, the only way to get lower is to use coil overs, the only way to keep your geometry and lower is with $3k lowering spindles.
http://forums.corvetteforum.com/c5-t...ng-the-c5.html
Old May 25, 2010 | 02:26 PM
jmoody66's Avatar
jmoody66
Default Sad but true
post below shows it
3k for dropped spindles is the best way but that is an overpriced option for such little gain. You can buy dropped spindles for trucks on the cheap which is a good indicator of how overpriced they really are.
