ABS and Traction Contol issue
Old May 20, 2010 | 08:17 AM
60Z's Avatar
60Z
Default ABS and Traction Contol issue
I've got an 01 Z06 with well worn brakes and the other day my ABS and Traction control lights popped on and have continued to stay on, could this be because the brakes need to be changed?
Old May 20, 2010 | 09:20 AM
dougbfresh's Avatar
dougbfresh
Pull the codes from the computer and post them-search for instructions on how to pull the codes from the dash.
OR see read this thread:
http://forums.corvetteforum.com/c5-g...-handling.html
Old May 20, 2010 | 01:58 PM
60Z's Avatar
60Z
C1214 Sol Valve Relay Contact or Coil CKT Open--This is what I'm getting for the TCS, is this a corroding issue?
Old May 20, 2010 | 02:18 PM
dougbfresh's Avatar
dougbfresh
Time for www.absfixer.com you can read all about it there.
Old May 26, 2010 | 12:24 PM
60Z's Avatar
60Z
This looks to be cheaper:
http://autoecu.com/parts_techinfo.php?id=19
Anyone familiar with these guys?
Old May 26, 2010 | 09:34 PM
Hi/Tek/Vette's Avatar
Hi/Tek/Vette
holy crap ..
who woulda figgerd ..
Old May 27, 2010 | 05:26 AM
trussme's Avatar
trussme
Default here are your options to fix that C1214 code
An alternative to buying a new EBCM is to have your original rebuilt.
For EBCM repair/replace
Call Brandon
877-648-7530 at ABS FIXER
or: www.absfixer.com
$150. plus UPS....warranted as long as you own it
OR…. get a REBUILT EBCM from these folks:
http://stores.shop.ebay.com/Digital-.../Homepage.html
http://www.autoecu.com/?gclid=CO-ozv...FR4UagodWwilqQ
http://www.speedometerrepairguy.com/
.....Brandon at ABS FIXER will warrant the fix for $150...that's a very good choice!....here's how to remove it:
The procedure for removing/replacing the EBCM is very simple. The only special tool you need is a T-20 Torx screwdriver.
I have a Craftsman tool set that has a 1/4" drive screwdriver with and adapter for many different size bit. Unfortunately, the adapter was too long to fit between the EBCM and water pump, so I purchased a set of Craftsman 5 pc. Torx screwdriver set that worked fine. A flathead screwdriver may also be needed to pry apart the EBCM from the BPMV
1 - make sure the car is off.
2 - You will probably need to remove the air bridge to get to the EBCM.
3 - Remove the wire harness by first removing the white plastic clip that locks it in place (I cut it off and replaced it with a zip-tie) , then lift gray handle and pull back on the wire harness . At this point, you will be able to see the second wire connection that is removed by pulling down EBCM.
The EBCM is on the left with the large wire harness coming into it and the sticker on top. The Brake Pressure Modulator Valve (BPMV) in on the right with the brake lines coming out.
4 - The service manual calls for you the remove the 2 insulator nuts that hold the BPMV to the brackets and lift the EBCM/BPMV out of the bracket. I do not think this step is necessary because there is plenty of room while it is still in the bracket and you do not gain much additional clearance since the brake lines restricts the movement.
5 - Remove the 6 T-20 Torx screws connecting the EBCM and BPMV - 1 on each corner and 2 on the sides
6 - "Separate the EBCM from the BPMV by gently pulling apart until separated" In this case, I had to use a flathead screwdriver to break the seal. Once it moved a little, the rest was easy. In addition to the rubber seal, each of the 12 holes has a peg in them from the BPMV. Don't go crazy, but be prepared to force them apart.
7 - At this point, all you've got to do is put it all back together. Push the new EBCM onto the BPMV.
8 - Replace the 6 T-20 torx screws
9 - Reconnect the wire harness
10 - Put the intake back on
.........IF YOU WANT THE PHOTOS THAT ILLUSTRATE THESE STEPS...just PM me your email address...
Old May 27, 2010 | 07:41 AM
lucky131969's Avatar
lucky131969
I agree, hard to beat a price of $0 ..........
To ABS and Traction Contol issue
