Hurst Review - ex-Ripper owner
Old Mar 18, 2002 | 04:00 PM
CDHough's Avatar
CDHough
Cruise-In II Veteran
Default Hurst Review - ex-Ripper owner
I installed the Ripper in my 99 coupe. I liked it a lot except for the rattle. I had the stock ****. I caulked the shift pattern cap and put wheel weights on the shaft which made it better.
I received the Hurst from RG at Exit28Motorsports (Thanks again for the fantastic deal RG!) I just installed it this afternoon and test drove it. It took me a little over an hour with no snags.
The Hurst does still make a slight vibration for me when I have my hand cupped on the **** when at full throttle sometimes. It seems quiter than my ripper was.
When I installed, I tried to pry the pin from the **** with two screwdrivers but it did not come out. I was also afraid if it did, it would go flying up into the roof. This is the most difficult part of the whole install. I ended up following the Hurst instructions. I used vice-grips and just rocked the grips from right to left until the pin pulled right out. To prep for the pin-pulling, I took a rag and cut a small hole in it and pushed the pin through the hole in the rag. This protected the shifter **** while leaving the pin easy to access.
In overview here are the things I notice:
1) My Hurst rattles less than my Ripper did.
2) It is easier to get into reverse with my Hurst than my Ripper.
3) They both feel about the same as far as the short throw and the crisp shifting.
4) I like having the shift stops with the Hurst, just in case of a hard shift.
5) I would recommend either but if I was going to do it again, I would get the Hurst.
- Charley
Old Mar 18, 2002 | 06:27 PM
3Vettes@Home's Avatar
3Vettes@Home
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Default Re: Hurst Review - ex-Ripper owner (CDHough)
Congrats! on the HURST! I feel the same way :cheers:
Old Mar 18, 2002 | 06:32 PM
Z06 Quin's Avatar
Z06 Quin
Great that you are pleased with the switch and feel it was worth it..(you can sell the ripper and get most your money back anyway).........I guess I'm lucky in that my Ripper doesn't rattle :cheers:
Old Mar 18, 2002 | 07:18 PM
CDHough's Avatar
CDHough
Default Re: Hurst Review - ex-Ripper owner (PoBoy Racer)
Sold my ripper with my 99 so this switch to the Hurst was from the Stock shifter on my Z06.
Old Mar 18, 2002 | 10:34 PM
jinki's Avatar
jinki
Thanks for information, Charley!
My baby is in garage from last December and I have replaced
the stock shifter with B&M Ripper a month ago. My C5 is still in hibernation mode.
(I though I was almost there yesterday. But I have 15Cm new snow today in Ottawa)
Many people in forum addressed some rattle problem using B&M and are saying
Hurst is better than B&M Ripper. So should I consider switch the Ripper
to Hurst again? But I never drive the C5 with even Ripper.
Give me your wisdom!
Old Mar 18, 2002 | 10:37 PM
fxrhm's Avatar
fxrhm
Default Re: Hurst Review - ex-Ripper owner (jinki)
Sounds like a great mod. I've had the ripper for two years and no rattle - so what's the story???
Old Mar 18, 2002 | 10:44 PM
CRUZMISL's Avatar
CRUZMISL
Default Re: Hurst Review - ex-Ripper owner (fxrhm)
It would appear some shifter rattle and others don't even though they are the same brand. My Hurst rattles a bit and I am using a Hardbar ****. It only does it under full throttle acceleration but it's not as quiet as stock which is to be expected given the direct link to the tranny. I am going to try some of the "fixes" out to see if it helps.
Joe
Old Mar 18, 2002 | 10:48 PM
jschindler's Avatar
jschindler
Default Re: Hurst Review - ex-Ripper owner (CRUZMISL)
My ripper does not rattle at all.
Old Mar 19, 2002 | 12:03 AM
MySea6's Avatar
MySea6
After reading all of these posts concerning the new Hurst shifter, I have a question.
Does no one else remember why B&M removed the shift stops from the shifter?
Word to the wise: Remove them before it's too late :yesnod:
Old Mar 19, 2002 | 12:24 AM
CRUZMISL's Avatar
CRUZMISL
Default Re: Hurst Review - ex-Ripper owner (MySea5)
No I Don't actually. Why?
Joe
Old Mar 19, 2002 | 01:05 AM
VetterMan's Avatar
VetterMan
After reading all of these posts concerning the new Hurst shifter, I have a question. Does no one else remember why B&M removed the shift stops from the shifter? Word to the wise: Remove them before it's too late :yesnod:
No I Don't actually. Why?Joe
To avoid the potential of synchronizer failure due to maladjusted stops.:seeya
Old Mar 19, 2002 | 01:13 AM
SHARK777's Avatar
SHARK777
RIPPER SHIFTER..no rattle JOSE ..BEST MOD IVE DONE .. this baby
loves THE RIPPER!!!!ITS LIKE SLICING A HOT KNIFE THROUGH BUTTER!!
RIPPER/HURST either one will do the job.BURN BABY BURN!!!
:jester :jester :jester :jester :jester :jester :jester :jester
:troll :troll :troll :troll :troll :troll :troll :troll :troll :troll :troll
:chevy :chevy :chevy :chevy :chevy :chevy :chevy :chevy :chevy
:chevy :chevy :chevy :chevy :chevy :cheers: :chevy :chevy :chevy
:cool: :cool: :cool: :cool: :cool: :cool: :cool: :cool: :seeya :seeya
Old Mar 19, 2002 | 01:20 AM
VERTVETTE's Avatar
VERTVETTE
Default Re: Hurst Review - ex-Ripper owner (rappskull)
Old Mar 19, 2002 | 03:37 AM
evil-1's Avatar
evil-1
Default Re: Hurst Review - ex-Ripper owner (VERTVETTE)
I need sunglasses after those posts. Anyway my ripper has been in for 18 months working perfectly.
There is a down side to performance shifters, they are tight\stiff\precise which makes them a bother to some. They were developed to make you shift faster and accurately.My ripper is silent ,try not to rest your right hand on shifter, it should be at 1 0'clock.....
Old Mar 19, 2002 | 10:20 AM
ambitin's Avatar
ambitin
Default Re: Hurst Review - ex-Ripper owner (evil-1)
My ripper doesn't rattle either but it is brand new and I understand that there have been some design changes over the years. Also, I had "The Master" Ken (mysea5) do the install and use his patented "flip the boot over biatch" install technique to minimize noise. I love the rippah!
Lates,
Justin
Old Mar 19, 2002 | 12:25 PM
CRUZMISL's Avatar
CRUZMISL
Default Re: Hurst Review - ex-Ripper owner (ambitin)
How do the shift stops cause synchronizer failures exactly. It doesn't make sense to me unless you had them adjusted so the car wasn't fully in gear. If you push forward fully into 3rd for example and adjust so the stop is still 1/16-1/8"away from the shaft you shouldn't have any issues :confused:
Thanks,
Joe
Old Mar 19, 2002 | 01:11 PM
CDHough's Avatar
CDHough
jinki,
Personally, I would not switch from the Ripper to the Hurst. They are very similar. If I had the stock shifter, I would go Hurst but even if I went Ripper, I would be happy.
It is strange that some shifters seem to rattle and others don't, even within the same brand. Maybe it has something to do with the installation.
- Charley
To Hurst Review - ex-Ripper owner
Old Mar 19, 2002 | 01:14 PM
CDHough's Avatar
CDHough
I would agree, it would have to be because the shift stops loosen and happen to move towards the shifter. I tightened mine pretty good.
- Charley
Old Mar 19, 2002 | 02:05 PM
MySea6's Avatar
MySea6
Default Re: Hurst Review - ex-Ripper owner (VetterMan)
Yup :yesnod: And the fact that the trannys have internal overhaul stops :cheers:
Old Mar 19, 2002 | 02:40 PM
zrchris's Avatar
zrchris
If your stops are leaving "play" in the lever when in gear, the stops have no way to cause a problem. The problems occur when they are set to inhibit full gear engagement. As I've said, the stops are really of little value because of the trans' internal stops. The shifter stops are only of value to abusive drivers who apply way too much force to the shifter. If you have any doubt about how to set the stops, or any concern of them causing a problem, just remove them.
B&M removed their stops for a variety of reasons- cost reduction, simplification, complaints from those not setting them right, and vibration noise when they would touch the stick.
Hurst still wants to incorporate them because when installed right they can be useful, and we want to give the extreme drivers what they want. But for many this feature is best removed.
Chris
[Modified by zrchris, 12:43 PM 3/19/2002]
