Installed ACA HID's.. 1 small problem
Old May 21, 2010 | 02:56 PM
REDZED2's Avatar
REDZED2
Default Installed ACA HID's.. 1 small problem
I just installed my ACA HID's I got from JW. Everthing went good. They work properly, throw amazing light, so I figured I connected it all correctly. However for some weird reason my hi beam indicator is always lit up on my gauge cluster. I dont know why this would be.
Anyone?
Old May 21, 2010 | 03:44 PM
SaberD's Avatar
SaberD
do a once over on your connections to the +terminal on the fuse box and the grounds in your battery tray area. These are the wires that allow the high beams to be on with the lows. something is wrong in your circuitry here. also make sure the ground you used is very clean. i drilled a new hole for mine because the bolt head broke off it was so rusted. also take a look at this great write up from Patches: http://forums.corvetteforum.com/c5-g...otsa-pics.html
Old May 21, 2010 | 06:15 PM
REDZED2's Avatar
REDZED2
Hey thanks for the suggestion. My connections are all very clean. the brights themselves dont turn on. Just the dash light.
Old May 21, 2010 | 08:07 PM
lucky131969's Avatar
lucky131969
Below is a simplified version of the ACA harness. I'm PM my number if you have questions.
Old May 22, 2010 | 12:48 AM
-DLS-'s Avatar
-DLS-
same here, but i just left it that way. My brights still work if i pull the lever back.
you need some perma-brights, then shoestring can be your best friend
Old May 22, 2010 | 10:35 PM
REDZED2's Avatar
REDZED2
Checked all wiring again, and all connections at fuse box area. Everything seems right. Not gonna worry, since other people have the same weird phenomenon. I get the jiggle at the cutoff area on bumpy surfaces, but I dont care. They still look sick awesome! Worth every penny! Thanks again Johnathan!
Old May 23, 2010 | 02:24 PM
lucky131969
Just to be clear. The brights indicator stays on all the time, or just when the low beams are turned on?
Old May 23, 2010 | 08:31 PM
REDZED2's Avatar
REDZED2
Hi. The brights indicator stays on all the time. Even when I pull the lever to turn on the brights. FWIW the brights indicator dims slightly when the brights are actually on. The indicator is brightest when no brights are on.
Old May 23, 2010 | 11:52 PM
JW Motorsports's Avatar
JW Motorsports
Banned Scam/Spammer
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17,'19,'22
I've never heard of this before after selling tons of these lights.
You don't have highs correct? If not something isn't right. Did you check your high beam fuses? Fuses on the harnesses?
The slight jiggle is normal with the pop ups. You just can't see it with stock bulbs.
They shouldn't bounce all over the place, but they might have a slight jiggle over bumps.
Old May 24, 2010 | 12:02 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Old May 24, 2010 | 04:18 AM
REDZED2's Avatar
REDZED2
Hey Johnathan. Its a slight jiggle only on bumpy surfaces or my backlane. No issues otherwise. No I DO have brights. EVERYTHING functions 100% normally as it should. Just the dash brights "blue light" is lit up as soon as I turn on my headlights. When I turn the brights on, it stays on as it should ( the dash light). Havent checked any fuses. Stranger things happened. Will do tomorrow. Thanks
Old May 24, 2010 | 09:39 AM
JW Motorsports
Banned Scam/Spammer
Wow. That's really odd.
To Installed ACA HID's.. 1 small problem
