Tester
Old May 22, 2010 | 10:09 AM
jtc44's Avatar
jtc44
Default Tester
: It is not cheep $400 From MAC tools but it will do eng. body abs tcs vss srs codes and some diag. It is made for OBD 2 1996 and up on the eng. side you can see live data and print out same I just got mine and still learning it I think mac and matco both sell it just a thought
Old May 22, 2010 | 05:34 PM
dougbfresh's Avatar
dougbfresh
You can get almost all the module codes via the DIC. I also use a PC based OBD tool that uses a laptop ( or handheld ) that graphs and runs some subsystem tests for about 1/2 the $400.
Almost all the OBD scanners I've seen don't really do EVERYTHING each manufacturer offers-just the Generic OBD stuff. You typically have to buy module upgrades for different manufacturers.
