A/C Codes
Old May 23, 2010 | 01:48 PM
BlueDragon's Avatar
BlueDragon
Default A/C Codes
My AC is throwing 2 codes B0363 and 0367 Left and right actuator feed back open. The only thing I see common in the ckt. drawings is that 10 amp mini fuse in the instrument panel electrical center. Where the heck is that?
I was feeling feisty today as I nailed my pesky C1716 code which was the F45 shock inop. cause I no longer have F45 shocks I went toi coil overs and the sim connector just needed to be reseated!
These two AC codes are the only other codes I have.
Old May 23, 2010 | 02:57 PM
BlueDragon's Avatar
BlueDragon
OK, I found the fuse and it is GOOD!
Could it be that both actators need to be indexed for some reason? The code is telling me the actuator feedback is staying above 4.?? volts and does not change for both actuators.
