Please Help PCM CODE PO300?
Old May 24, 2010 | 05:59 PM
Techsan's Avatar
Techsan
Default Please Help PCM CODE PO300?
I reset all the codes and the check engine light came back on with U1064 AND THE PCM CODE WAS P0300 any ideas of where I should look first, I looked at the codes and one was loss of communication with the BCM and the other was engine misfire. The check engine light actually did not come on today. Should I start with the spark plugs and wires, I know the wires are stock and the car has 45,000 miles on it? Thanks for any input.
Old May 24, 2010 | 07:57 PM
Techsan's Avatar
Techsan
ttt
Old May 24, 2010 | 08:50 PM
dougbfresh's Avatar
dougbfresh
0300 misfire is actually multiple RANDOM misfires. You have more than 1 cylinder misfiring. CEL typically FLASHES during these events. Plugs and wires are the easiest way to start but can be broken valve springs (rash of these lately), multiple injectors plugged up not to mention 2 or 3 other possibilities (coils, power wires chaffed on the back side of the cylinder heads, one guy had bent pushrods a week or so ago,...)
Old May 24, 2010 | 08:57 PM
Chris Stewart's Avatar
Chris Stewart
I left a plug wire unsecured by accident and got the 0300. oops Funny part is I barely noticed the power loss that I was dropping a cylinder.
Old May 27, 2010 | 01:12 PM
Techsan's Avatar
Techsan
Replaced the plugs and wires, the code has not came back, car is running a lot smoother,
To Please Help PCM CODE PO300?
