Driver's side window
Old May 25, 2010 | 05:00 PM
SCPDLARRY's Avatar
SCPDLARRY
Default Driver's side window
Hi Guys,
My driver's side window will not go down. When I press the down button, I hear a click noise. I've heard this complaint before on the Forum, but I don't remember the cause of the problem.
Old May 25, 2010 | 07:25 PM
Bakersfield's Avatar
Bakersfield
Start by reading my post on this subject.
http://forums.corvetteforum.com/c5-g...w-problem.html
Basically, with the ignition key on, hold the window down button and slam the door closed real hard a couple of times. That might free up the motor. Unfortunately, this is a common problem.
Old May 25, 2010 | 09:38 PM
Nick1's Avatar
Nick1
Probably the window motor is shot! Mine went when the car was relatively new.
Do a search and you will see a lot. Seems to run with GM for some reason.
Old May 26, 2010 | 03:16 PM
sts57c5's Avatar
sts57c5
I just had to pay to have my window regulator replaced .
To Driver's side window
