grinding into 3rd
Old May 26, 2010 | 04:01 PM
HeathZ51's Avatar
HeathZ51
Default grinding into 3rd
2002 c5 corvette, bolt on-s, ls7 clutch and flywheel, zo6 slave cylinder and master cylinder.
just had my clutch, flywheel, slave and master cylinder replaced less than 1000 miles ago by a performance shop. car started grinding when shifting into 3rd about 5 days ago. then started grinding into 4th occasionally. now it seems harder to pull out of gear then usual. 5th especially. the shop is telling me its the transmission. just doesnt seem correct to me. is this not a clutch or shifter problem?
Old May 26, 2010 | 04:23 PM
HeathZ51's Avatar
HeathZ51
also grind into 3rd on upshift and downshift and grinds into 4th on downshift only. upshift into 4th is fine.
Old May 26, 2010 | 05:56 PM
Trios's Avatar
Trios
Change your transmission fluid (likely a good idea either way), if there is no change/improvement in the grinding then its not likely the trans, as new fluid seems to make an improvement in most cases here where the synchros are having some trouble.
Old May 26, 2010 | 07:56 PM
1sickz51vette's Avatar
1sickz51vette
If the syncro's are shot though, changing the fluid won't do much... Does the clutch pedal feel "weak"? How many miles on the tranny, and did it grind before the shop had it?
Old May 26, 2010 | 10:09 PM
TonyVette396's Avatar
TonyVette396
Sounds like the EXACT same problem I had in my '99. Changed to Royal Purple Synchromax. No help. Realigned shifter. No help. Bled the hydraulics...BIG help. My clutch wasn't fully disengaging due to air/junk in the system. Hope this helps!
Old May 29, 2010 | 09:00 AM
HeathZ51's Avatar
HeathZ51
after talking to tick performance and east coast performance and doin a few road tests, all fingers pointed to the keys in 3/4 and the blocking ring in 3rd is most likely cracked or damaged. so the vehicle is at east coast performance getting looked further into. i pushed the clutch all the way in in 1st and ran the rpms up past 5000 and car didnt move a bit, and figured that test took something wrong with the new clutch and slave cylinder out of the question, thanks for all of your inputs
To grinding into 3rd
