TPS question ?
Old May 26, 2010 | 09:31 PM
soggysailor's Avatar
soggysailor
Default TPS question ?
Just had new tires installed on the rear. 1 sensor is not responding. OK maybe its dead or.....? So I do a relearn and each TPS responds and gives a BEEP(horn), even the RR that is suspect. So I'm thinking all's well and it healed. No it still is not giving a pressure. So is it time to replace or? I thought if you got a Beep when you do a relearn you were good.
Old May 26, 2010 | 10:10 PM
byronhunter's Avatar
byronhunter
Did you take it for a drive?
Old May 26, 2010 | 10:28 PM
jrose7004's Avatar
jrose7004
If it were me I'd have replaced them when I got the new tires.
Old May 26, 2010 | 10:42 PM
soggysailor
What's that they say about hind site?? 20/20.
I've got a couple in the garage, I may do the battery replacement and then swap them out. America's Tire will do the swap I believe for free.
To TPS question ?
