no fuel pressure question
Old Jan 3, 2012 | 02:08 PM
Racetronix's Avatar
Racetronix
Supporting Vendor
Originally Posted by FordDefector
I know this is an old thread, but maybe someone can help me.
I have an '01 C5 and only have 5 psi fuel pressure with the key on. It has a Racetronix fuel system with the harness that runs power direct to the pump. It was installed by the previous owner and I tried contacting Racetronix to get instructions or a wiring diagram and never heard back from them.
The car ran fine for a long time after I bought it. It just quit on me one day and now no fuel pressure.
Fuse and relay both tested good.
On the factory fuse block I measured voltages and I have no voltage on 87 where I should have constant 12V.
I do get 12V on 86 when I turn the key on.
Does anyone have info on how the Racetronix stuff is wired in?
Any ideas would be appreciated.
Have you joined our support forum where there are diagrams and diagnostic docs?
Old Jan 3, 2012 | 02:46 PM
dougbfresh's Avatar
dougbfresh
If your getting any pressure, the electric to the pump is most likely OK and the pump is shot.
Old Jan 8, 2012 | 05:18 PM
FordDefector's Avatar
FordDefector
No, didn't realize there was a forum. I will do that, thanks.
Old Jan 9, 2012 | 09:01 AM
Toby Van Horn's Avatar
Toby Van Horn
Well when I ttraced mine back to pump I was getting voltage. The pump was fried. I bought exact pump swapping was easy because all the wiring was the same. Kit was cheap also. Of course mine died with a full tank go figure. Good luck
Old Jul 28, 2012 | 02:08 AM
jose08m5's Avatar
jose08m5
I was able to find the direct power harness that goes from the alternator to the fuel pump. The 20A fuse there was melted. It apparently had gotten very hot before it blew, almost like when you have a big amp with a power wire that is too small, but it's 10 gauge wire.
I replaced it and ran the car for a while and the fuse didn't get hot and had good stable fuel pressure.
Where is that fuse as i'm having the same problem?
Old Jul 28, 2012 | 06:46 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
I responded in the other thread but I saw you posted here and then clicked on your profile...I also have an IC Maggie and had intermittent fuel problems but not as bad as you. If your install is like mine you have your coolant tank on top of your battery...look under there and there are 2 inline fuse holders for your magnavolt...open them up and pull out the fuse...one of mine literally came apart in my hand
I ended up going to Radio Shack for a 10ga inline fuse holder and splicing it it...no problems since if this is the case with you I recommend calling any auto parts place before you go as they don't all carry inline fuse holders with 10 ga wire...Radio Shack or stereo shop is your best bet.
Good luck!
Old Jun 22, 2019 | 11:16 AM
Argentimage's Avatar
Argentimage
Originally Posted by lucky131969
Any other important info you'd like to share?
If you are checking at the relay socket(i.e relay removed), you should have the following(as label in the pic):
Measurements taken key to on position:
30 = O volts
86 = 12 volts ( for two seconds)
87 = 12 volts ( constant)
Measurement taken key to off position:
85 = Ground (should be low resistance i.e. .3 ohm or below)
No offense, but I'm questioning how you are taking the measurements, since all these things failing at the same time are unlikely....unless the car has been in an accident.
When you jump 30 to 87(of the relay socket), you should have 12 volts at the fuel pump connector.....unless there is a wiring problem.
There should be a ground at 85.....unless the ground is corroded at SP122 (located under the battery tray), or G105 (left lower side of block) is damaged.
There should be 12 volts at 86 when the key is first turned on, unless the PCM is not providing it.
http://forums.corvetteforum.com/c5-t...e-grounds.html
I know this is old, but new to these cars ... same issue was running and right after a fill-up died.
Question on ground definitions...
When you say Under battery tray - there isn't any under there. There IS one on the frame NEXT to the battery - is that the one to which you refer?
Left side of engine - near the oil filter? - is that a small wire that screws to the block, and also has a radio ground?
Or is it in a different location?
thanks
Old Jun 22, 2019 | 12:03 PM
feeder82's Avatar
feeder82
This link has the ground locations
https://www.corvetteforum.com/forums...tion-long.html
Old Jun 22, 2019 | 12:12 PM
Argentimage
Originally Posted by feeder82
I have been there on that one,
there isn't any ground under the battery
where & how do you get to the left side engine ground, if it is NOT the small diameter wire I mentioned, that is shown in this thread...
https://www.corvetteforum.com/forums...-location.html
Old Jun 22, 2019 | 12:39 PM
feeder82's Avatar
feeder82
The left side (drivers) engine ground strap is woven wire, its right below the brake booster on the frame
Old Jun 22, 2019 | 02:06 PM
Argentimage
Got that one too, thanks.
How do you get to the other end of the "pinky finger diameter" ground wire from the battery?
Old Jun 22, 2019 | 03:06 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
If you are trying to troubleshoot a fuel pressure issue I did a YouTube video a while back on how to check the pump relay circuit !!
Old Jun 22, 2019 | 04:11 PM
  #33
Argentimage
Nice video, thanks for posting.
I did most of this yesterday, and can confirm with the test light procedure you showed in the video all grounds referenced are OK, PIN 30 & 85. In reality all these grounds were disassembled and cleaned which meant broken pins turned into screws with serrated washers to help maintain grounds.
So at this point it is looking like a fuel pump module, unless there is a specific test that can be done at the pump.
Old Jun 22, 2019 | 04:55 PM
  #34
C5 Diag's Avatar
C5 Diag
First off can you include the year of the car in your profile or in your initial thread...this helps us to help you !!...now is the car a cranking no start ??...if you jump pins 87 and 30 at the relay does the pump run ??...the more info you can pass on the better...if it doesn’t run now you have to access the pump at the bottom of the left fuel tank if you own an early 2003 and prior and check your power and grounds at the pump...my ‘01 fuel pump draws around 6 amps at 5350 RPM at idle !!...have you checked fuel pressure at the fuel rail ??
Old Jun 22, 2019 | 06:20 PM
  #35
Argentimage
97 as in the start of this thread
i have done all the ground checks indicated and
i did the pin jumps shown in the video
the cars cranks
the car will try to run on ether if you shoot that in the inlet
no fuel pressure though when it initially died right after a fill up I did hear the pump prime once. After that the last few days, haven’t heard it run for that two seconds on key on
The fuel sender unit appears to have been “serviced” at some time in the past
the test you mentioned Is new, had not seen that one
I will need to try in next day or so
Old Jun 22, 2019 | 06:36 PM
  #36
C5 Diag's Avatar
C5 Diag
Ok, your best bet is to access the pump and remove the connector and then apply 12 volts to pin A ( gray wire) and a ground to pin D ( black wire) of the pump...if the pump does not operate its toast !!
Old Jun 24, 2019 | 10:41 AM
  #37
Argentimage
OK battery to the gray and black the pumps runs.
How do I check the wiring back to the pump?
Next question is the battery ground cable - where does that go - to upper left side of engine (?) and how to access that if in fact that is where it goes...
To no fuel pressure question
Old Jun 24, 2019 | 11:29 AM
  #38
C5 Diag's Avatar
C5 Diag
Don’t know if you jumpered pins 87 and 30 at the fuel pump relay ??...pump should run !!...if not see if you have power at the gray wire at the connector with 87 and 30 jumpered together...ground is G 401 at the frame rail Inboard of the left rear tire...remove the wire terminal at G401 and using an ohm meter see if you have continuity between the black wire at the connector and G401 !!
Old Jun 24, 2019 | 12:04 PM
  #39
Argentimage
I had done that and any of the other diagnostics up front - as a part of reading this thread....
All the studs busted and were repaired and cleaned up, hopefully that will clean up some of the ghosts I had seen over the last month or so - but were not present at time the car quit.
Big update, something told me look at the relays.... it was a bad or wrong after-market relay.
Thanks for all the help,
Old Jun 24, 2019 | 12:17 PM
  #40
C5 Diag's Avatar
C5 Diag
If you think the fuel pump relay is bad swap it with another !!...I use the horn relay !!
