Mounting Nitrous Bottle...How'd you do it?
Old Mar 19, 2002 | 06:20 PM
RajunCajun2001's Avatar
RajunCajun2001
Default Mounting Nitrous Bottle...How'd you do it?
I plan on mounting it in center rear compartment, and I have a remote bottle opener and warmer. What's the best way to mount the bottle? Want to be sure its easy to remove when its time to get it refilled.
I'm all eyes and ears!
Old Mar 19, 2002 | 06:43 PM
C5-VERT's Avatar
C5-VERT
Cruise-In IV Veteran
Default Re: Mounting Nitrous Bottle...How'd you do it? (RajunCajun2001)
Here is something for the eyes...
No need to get fancy as no one can see it anyway :cheers:
Old Mar 20, 2002 | 01:06 AM
Ron Price's Avatar
Ron Price
Default Re: Mounting Nitrous Bottle...How'd you do it? (C5-VERT)
Can you tell me if the bottle is mounted to a plate or board which is in turn fastened to the bottom of the storage compartment? Since I am considering doing the same thiing, please fill me in on all the details. TIA
Old Mar 20, 2002 | 02:24 AM
jetskifast's Avatar
jetskifast
Default Re: Mounting Nitrous Bottle...How'd you do it? (Ron Price)
Mounted my bottle to copper plate. Make sure and rotate bottle about 35 degree angle to take advantage of bottle siphon tube.
Also make sure and install blow off vent line, its a nice safety:)
There is no need to bolt mounting plate down, if you cut mounting plate correct, fit will be tight.
Old Mar 20, 2002 | 02:40 AM
C5-VERT's Avatar
C5-VERT
Default Re: Mounting Nitrous Bottle...How'd you do it? (jetskifast)
Any reason why you used a copper plate? I just carpeted a 1/2 sheet of particle board.
Did you just drill a hole for the blow down line? I need to go ahead and do mine...
Old Mar 20, 2002 | 03:13 AM
jetskifast's Avatar
jetskifast
C5-VERT
I happened to have some nice polished cooper plate around :cool:
Yes I did drill hole for blow down line, also used rubber groumet to seal line in hole.
Old Mar 20, 2002 | 08:54 AM
shftn6's Avatar
shftn6
board with carpet made to fit exact size.
Old Mar 20, 2002 | 10:38 AM
C5-VERT's Avatar
C5-VERT
Default Re: Mounting Nitrous Bottle...How'd you do it? (shftn6)
Are you able to get all of your nitrous out with your bottle NOT angled?
Old Mar 20, 2002 | 10:55 AM
shftn6's Avatar
shftn6
Not sure exactly what you mean. The top of the bottle is higher than the bottom if that is what you mean. The brackets from TNT take car of that. Maybe the photo doesn't show the angle all that well.
Old Mar 20, 2002 | 12:00 PM
rwj383's Avatar
rwj383
since i sell, install and service nitrous, i installed mine out in the open for 'advertisement' purposes. i spend a ton of time at the track. the kids go nuts when they see it. promotes sales. + i wanted the 15lb bottle.
[Modified by rwj383, 10:00 AM 3/20/2002]
Old Mar 20, 2002 | 03:38 PM
RajunCajun2001
Default Re: Mounting Nitrous Bottle...How'd you do it? (rwj383)
Everyone has an awesome setup! I can't wait to leave work to start on mine!!! I plan on mounting the bottle to a piece of carpeted wood so I can just take the entire thing out when I need it refilled. Thanks for the tips guys!
RWJ383, 208 mph!!! :eek: :eek: :eek:
Old Mar 20, 2002 | 03:51 PM
C5-VERT's Avatar
C5-VERT
I noticed your bottle was not rotated 35 degrees like most people do. That way under accelaration all of the nitrous gets picked up.
Old Mar 20, 2002 | 03:59 PM
shftn6's Avatar
shftn6
Thanks, I will do that.
Old Mar 20, 2002 | 04:03 PM
Sales@MVPAutoParts.com's Avatar
0Sales@MVPAutoParts.com
Former Vendor
jetskifast,
What kind of fitting did you use to replace the blow down tube? Is that a NPT to 6AN fitting?
-Tuan
Old Mar 20, 2002 | 10:59 PM
Ron Price's Avatar
Ron Price
Will the track inspector pass the N2O without the plate being mounted to the storage compartment or aren't they checking that close. Shiftn6, what is the little black and red box? Also, will the storage compartment cover filt flat with your install?
Everyone, Where did you run your main N2O line and why?
Everyone, this info is really great!! I hope to use bits and pieces of the things you have done.
Thanks for all the input!!
Old Mar 21, 2002 | 12:02 AM
C5-VERT's Avatar
C5-VERT
If you make the Plate/Board the right size it fits very snug. Trust me, it will not move.
I am pretty sure most people run the nitrous line down the right side of the car and through the rubber grommet in the firewall that is located behind the battery. Very simple. :cool:
Old Mar 21, 2002 | 10:22 AM
shftn6's Avatar
shftn6
It is a Mallory Window Switch. Right now I can't put the cover on because of the blowdown tube. I am currently changing that tube to a braided hose, then the cover will fit.
To Mounting Nitrous Bottle...How'd you do it?
