where to get an engine support
Old Jun 2, 2010 | 01:04 PM
prochargedz's Avatar
prochargedz
Default where to get an engine support
I am in the process of ripping out my clutch. Where do I get the straight jack to hold the oil pan up when i remove the clutch so there is no damage to the car. I looked and couldn't source one. Can I use a let's say.... dry wall hold up things at home depot? thanks
Old Jun 3, 2010 | 09:13 AM
prochargedz
bump dittty
Old Jun 3, 2010 | 01:02 PM
Jewjenk's Avatar
Jewjenk
STORE
Old Jun 3, 2010 | 01:19 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
You can use a floor jack, a stack of wood blocks or a hyraulic bottle jack with a piece of wood under the oil pan for support.
Old Jun 3, 2010 | 08:52 PM
johnson-rod's Avatar
johnson-rod
I used a 71 Pinto jack and a block of wood.
To where to get an engine support
