Brake lights are not working
Old Jun 2, 2010 | 08:59 PM
Dr. Gonzo's Avatar
Dr. Gonzo
Default Brake lights are not working
All 4 brake lights on my 99 FRC don't work but the small center brake light does. The turn signals, running lights and hazard lights work fine though. The car only has 32k miles on it. The previous owner had euro tail lights [is back to stock now] but I was told the brake lights are not effected when doing this anyways. I searched and didn't find any definite answers.
Any input?
Old Jun 2, 2010 | 09:12 PM
Blown 346's Avatar
Blown 346
Have you checked your grounds?
DIXZ's Avatar
DIXZ
Do a search on multifunction switch. You will find schematics, and detailed instructions on repairing\replacing this unit.
Old Jun 2, 2010 | 10:02 PM
lucky131969's Avatar
lucky131969
Any input?
To be clear....you removed the euro tail lights, and returned it to stock? Have the brake lights ever worked?
Old Jun 2, 2010 | 10:37 PM
Dr. Gonzo's Avatar
Dr. Gonzo
Yes, the previous owner reinstalled the stock tail lights before selling the car and they worked fine.
Old Jun 3, 2010 | 08:23 AM
blazer427X3's Avatar
blazer427X3
This exact same thing happened to me !
When I bought my car the previous owner had installed Euro tail lights too. I like the stock ones better so I asked him to re-install them. On the drive back to Ohio another motorist told me during a fuel stop that I had no brake lights except for the center one. A quick stop at a Chevy dealer confirmed this and the mechanic discovered a cut wire under the dash area on the drivers side. It took him less than 5 minutes to find it. I am guessing that part of the install for the Euro lights involved cutting a wire in that area. Try looking for a cut wire under dash in the footwell area on the drivers side, close to the kick panel. I bet you find one !
Old Jun 3, 2010 | 12:22 PM
Dr. Gonzo's Avatar
Dr. Gonzo
I was told by the previous owner that the euro lights do require a wire to be cut but when going back to stock one would think this wire would be properly reconnected (solder & heat shink). I'll take a look to see if I see any loose wires. If not, I guess I'll have to start with a new hazard switch then a new multifunction switch.
Old Jun 3, 2010 | 12:40 PM
lucky131969
Troubleshoot, not crap shoot. You can isolate this issue with schematics and meter. Don't spend money if you don't know it's broke!
Old Jun 3, 2010 | 12:53 PM
Dr. Gonzo's Avatar
Dr. Gonzo
Where can I find the necessary wiring schematic?
Old Jun 3, 2010 | 01:00 PM
Jewjenk's Avatar
Jewjenk
Did you bother to ask if he pieced that wire back together? Why not contact him to find out if it was done and if not, then maybe he can tell you exactly where it is so you don't waste your time looking at schematics.
Old Jun 3, 2010 | 01:03 PM
Dr. Gonzo's Avatar
Dr. Gonzo
I did contact the previous owner. He had ECS do all the work on the car so he doesn't know. I'm hoping a bad connection is all it is.
Old Jun 3, 2010 | 01:52 PM
lucky131969
I will provide those...give me a few minutes.
Old Jun 3, 2010 | 02:11 PM
lucky131969
Ok. Since the third brake light is working, that tells me that the brake pedal switch is working normally; however, there are two outputs directly out of the stop lamp switch. One output goes to the third brake light, and the other to the rear tails. While I'm not familiar with the euro setup, it seems the white wire to the hazard switch is cut, when they are installed (as previously mentioned in this thread), so that would be worth a quick look.
Old Jun 3, 2010 | 05:14 PM
Dr. Gonzo's Avatar
Dr. Gonzo
I owe you a beer!
I pulled the plastic off from under the steering column and there it was, a cut white wire. I made a proper connection and that did it. All the outer lights and the center brake light work now.
Old Jun 3, 2010 | 05:43 PM
blazer427X3
Glad you found the problem ! Nice job on the diagnosis Lucky
Old Jun 3, 2010 | 06:58 PM
lucky131969
You called it bro, I just supplied the schematics
Old Jun 4, 2010 | 01:03 AM
Camjamsdad's Avatar
Camjamsdad
From: It's true money can't buy happiness, but it is more comfortable crying in a Corvette than on a bicyc
St. Jude Donor '13
Really?
To Brake lights are not working
