Newbee 2000 coupe. Muffler question.
Old Jun 2, 2010 | 09:21 PM
jhcessna's Avatar
jhcessna
Default Newbee 2000 coupe. Muffler question.
Is it possible to change mufflers without a lift? I have a good shop jack and stands but no lift access. It has an unidentified borla exhaust on it now, I'll post some pictures when I get the car and see if somone can tell me what kind they are.
Joe
Old Jun 2, 2010 | 10:27 PM
rodsvet's Avatar
rodsvet
Why change them? Borla's don't sound too bad. If the system isn't welded you can get it done on jack stands. I had a muffler shop do mine for $75.00, and then tack them at the joints after he got them straight. Been on 10 years and still sounds good. They are B&B route 66's and are quiet until you push the loud pedal. Good Luck!! rodb
Old Jun 2, 2010 | 10:31 PM
jrose7004's Avatar
jrose7004
Muffler shop installed mine for $75.00 also. You'd need to get the rear of the car up quite a ways to do it in your driveway.
Old Jun 2, 2010 | 10:42 PM
j0n's Avatar
j0n
I did my catback in my driveway. Was able to pull one side out without cutting it... but the other I had to cut. The hardest part was getting the tips right.
Old Jun 3, 2010 | 07:21 AM
RSchleder's Avatar
RSchleder
I also did my Corsa install on my driveway. I cut the OEM pipes to remove them since they are worth little to nothing. Would have been worth the $75 to have a muffler shop do it though.
Old Jun 3, 2010 | 08:21 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
I installed my Z06 TI's on over a garage floor pit.
No jacking, lifting, or cutting required!
To Newbee 2000 coupe. Muffler question.
