wheel size help please
Old Jun 2, 2010 | 10:56 PM
1320IN9's Avatar
1320IN9
Default wheel size help please
i am looking into a set of ssr wheels, 18x9.5 +50 offset and 19x10.5 with a +62 offset. do these numbers sound right for a 03 zo6? i was told they will be fine but want to make sure.. thanks
Old Jun 3, 2010 | 11:58 AM
99blancoss's Avatar
099blancoss
Former Vendor
St. Jude Donor '10-'11-'12
Here is a great picture to explain it and part of the article it came from.
Determining the actual backspacing of a wheel is easy. Since it's the distance from the mounting surface to the edge of the inboard side of the wheel, it simply needs to be measured. With the wheel facedown, rest a ruler horizontally along both edges (beads) of the wheel. Now take a tape measure and measure the distance from the ruler to the mounting pad of the wheel. That figure is your backspacing. Calculating a wheel's offset is even easier. Measure the wheel's overall width, subtract its backspace and divide by two.
http://www.fourwheeler.com/techartic...tte/index.html
