What will my compression ratio be?
Old Jun 3, 2010 | 02:44 AM
Vettedriver986's Avatar
Vettedriver986
Default What will my compression ratio be?
Im building a forged 347 wth 6.125 rods, stock stroke, and -9cc inverted dome pistons. I will be using stock mls gaskets and 317 heads with the larger chambers than what came on my ls6.
What should my compression be? i calculated a hair under 9:1 but wanted to be sure
I will also be using the stock ls6 cam if that matters
Old Jun 3, 2010 | 07:53 AM
99blancoss's Avatar
099blancoss
Former Vendor
St. Jude Donor '10-'11-'12
assuming 10 out of the hole and a 70 cc chamber 9.08 is what I get
(.051 hg thickness and 4.080 bore)
Old Jun 3, 2010 | 08:52 AM
chevy406's Avatar
chevy406
Should be a 3.898" bore for a 347. With a 70cc combustion chamber and approximately .007" piston crown above the deck, you will indeed be between 9.0 and 9.1
Old Jun 3, 2010 | 11:10 AM
Vettedriver986
isnt the combustion chamber of those heads 71CC? Does that make much of a diff vs 70cc?
Old Jun 3, 2010 | 11:51 AM
99blancoss's Avatar
099blancoss
Former Vendor
drops it to 8.99 with a 3.903-3.905 bore.. little bit lower with a smaller bore
Old Jun 3, 2010 | 12:26 PM
Vettedriver986
can I also use a thicker head gasket to drop it a little lower? IDK if near 8.5:1 can be obtained, but it would be great for my big turbo.
Old Jun 3, 2010 | 12:54 PM
99blancoss's Avatar
099blancoss
Former Vendor
the LS9 is thicker, and will drop it more... .053 IIRC 8.95, use a deeper dish piston. around a -14.5
-14.5 cc dish and .053 with 4.080 hg bore is 8.49
Old Jun 3, 2010 | 01:31 PM
Vettedriver986
whats the stock 6.0 mls gasket thickness guys? .051??
Old Jun 3, 2010 | 11:36 PM
chevy406's Avatar
chevy406
have you fully researched the ideal compression ratio for a boosted LS1? Most people are running 9 or 9.5 static compression for a boosted LS1. My 408 that I just built for twin turbow calculates right at 9.0, and Shawn from Virginia Speed said I am leaving some power on the table by not bumping it up to 9.5. These GenIII engines have very efficient combustion chambers, coupled with good quench pads. You have to think outside the box from the old SBC days.
Old Jun 3, 2010 | 11:44 PM
99blancoss's Avatar
099blancoss
Former Vendor
The flip side being if you stay conservative your generally safer with more boost. We've seen them from 8.6 - 10 all depending on a s/c or turbo and the customers personal taste
To What will my compression ratio be?
