I'm in the process of removing the forward console bezel (the one that surrounds the radio and AC control). I have the bezel loose but cannot completely remove it due to interference from the rear cigarette lighter.
How does this bloomin lighter come out? It doesn't screw out, there is no clip, it's not a pressure fit.
Disconnect it from the back really easy. Once you have everything else loose you can get your hand back there and voila. I've done mine several times. If the above doesn't work here you go. http://www.vetteessentials.com/instr...zel_howto.html
HELP!
I have the same situation. It looks like we leave it in place and pull the consold from font to back.
Yet that didn't work either!
