Tip for installing the bilstein sport shocks
Old Jun 4, 2010 | 12:27 PM
THE FLASH's Avatar
THE FLASH
Default Tip for installing the bilstein sport shocks
This tip may have already been introduced (if it has I did not see it), if not here goes. For those who do not want to remove the fluid resivours directly above the front passengerside and front driverside shock, get the correct size allen wrench and cut off 60% of the short side of the allen wrench. it will fit and make keeping the shaft from turning as you tighten the nut down. It worked really well and made the install easy at least for me. My .02
