codes came up :/
any ideas?
Shocks Inoperative
Service Ride Control
Reduced Engine Power
Check Tire Pressure
Service Vehicle Soon
Low Fuel
Door Ajar
At the same time, the following items stop working:
Gas gauge
Temp gauge
Oil Pressure gauge
Door locks
Mirrors
not sure if this is relative but the car recently had a leaking clutch line and the torque tube had to come out to replace it.
I put it in the garage and 5 days later and it started doing it again. I ran codes and came up with the following.
10 pcm 1 code p1626h
28 tcs 2 codes u1301h, u1016h
38 rtd 1 code u1016h
40 bcm 5 codes b0432h, b2647hc,u1255h,u1016h,u1096h
58 sdm 1 code u1301h
60 ipc 8 codes u1255h, u1064h, u1016h, u1040h, u1176h, u1056h, u1088h, u1160h
ao ldcm no comm
a1-rdcm 6 codes b2283h, b2285h, u1255h, u1064h, u1016h,u1096h
a6-scm 5 codes b0851h, u1300h, u1255h, u1016h, u1064h
borfa 5 codes u1255h, u1096h, u1064h, u1016h, c2120h
anyone have any ideas?
thanks
B2283 Battery #1 Fault
B2285 Battery #2 Fault
B2265 Horizontal Position Sensor Fault
U1064 Loss of Communications with BCM
TCS
C1295 Brake Lamp Switch Circuit Open
PCM
P1433 Fuel Level Sensor 2 High Voltage
