Well if you've asked yourself this question, and have posted questions on this forum, which many of you have(including myself :yesnod: ) then check out this link: http://www.howstuffworks.com/torque-converter1.htm
Re: How does a torque converter work? (Buckmaster)
My name is Doug and I shift gears.
Articles were intersting. Could someone say though in basic English what has the torque be MULTIPLIED through a TC? It seems like the best you could do is 1:1 with the converter locked. Splain that to me and you might win a convert (no pun intended).
Oh...and hold down the button too long and you engage the passenger seat ejector....but that was FULLY covered in another thread. :D
Call 1-800-284-3433 and talk to a sales guy at ATI Performance Products. They can tell you excatly how a Tourque Converter works and why it can effectivly multiple tourque. One thing the Howstuffworks.com site doesn't talk about is K factors and various other ways the stall speed and fin angle can multiple tourque. I would answer but I spealize on the Crank Shaft Dampers.
Ok I think the entire concept of multiplying torque probably could be explained as a lever or as a set of two fans (turbine conected to engine, and pump conected to driveshaft) and a round wedge (stator). If fluid is shunted from a small internal fan (turbine), to the outer edges of a large fan (pump) via a wedge shaped object (strator), then the fluid which was once revolving in a small circumferance/ orbit, will be moved to a larger circumferance/ orbit. This would effectivly multiply torque (torque = Force X distance from a fulcrum or orbit of rotation). After the converter locks, there would be no more multiplication of torque. Its just like gears with a little gear turning a bigger gear and multiplying torque. Also ofcourse it allows you to use it for its real purpose (reving higher at a standstill so you obtain more power just as you break away).
DISCLAMER: The author has no clue what the hell he is talking about it, but if it does work like this then splendid. :lol:
Torque is not multiplied when the TC is locked. Only when the engine speed is much greater than output speed. Like when you stnad on the brake & rev the engine up to the TC's stall speed!
