opening the engine "oilpan"
Old Jun 5, 2010 | 08:54 PM
baezi z06's Avatar
baezi z06
Default opening the engine "oilpan"
hi
i was wondering can i get to the rods and pistons whith out taking the front bit away ,
it looks like it here on ths pic but i´m not sure if it´s enouch to get all the way up... to the rods
was tol i needed to take the bit down first
bazei
Old Jun 5, 2010 | 09:45 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
perhaps you should tell us what you're trying to accomplish?
if you're just trying to change out rod bolts or something then yes, you can pull the oil pan from the bottom and change them out. if you're trying to pull the pistons then well, i'm not sure. i know with some of the v6 cars i've worked on you couldn't them out from underneath..but i'm not sure on these
Old Jun 6, 2010 | 04:58 AM
baezi z06's Avatar
baezi z06
i need to get to the rod´s bolts an bearings, and then i´m gona pull the pistons up, the heads are off.
but the question is, do i need to take bit or (the rack) or what it´s called down, or can just take the pan under there
baezi
Old Jun 6, 2010 | 07:02 AM
Rob's 73's Avatar
Rob's 73
You will need to drop the cradle to lower the entire oil pan. The lower pan will not expose the crank at all. After the oil pan you will need to take off the windage tray. You are better off removing the entire short block.
Old Jun 6, 2010 | 08:36 AM
baezi z06's Avatar
baezi z06
I thought so....
i´ll lower the cradle down, so i can open it all up, but i´m gona change out the parts whith the engine in the car.... less job....
i´m doing this in my garage whith no carlift...
thanks
baezi
Old Jun 6, 2010 | 02:01 PM
Rob's 73's Avatar
Rob's 73
After you lower the cradle the engine will come out pretty quick. I'll bet it will be more work trying to get the pistons out with the shortblock in. I have had my motor out three times without a lift.
Old Jun 6, 2010 | 02:13 PM
schpenxel's Avatar
schpenxel
St. Jude Donor '15
agreed. it's a lot easier to just pull it out..
To opening the engine "oilpan"
