Need heads swap, step by step.
Old Jun 6, 2010 | 03:11 PM
justin_heat05's Avatar
justin_heat05
Default Need heads swap, step by step.
I need pictures and description on replacing my heads from square one.
98 corvette coupe ls1
Old Jun 6, 2010 | 03:32 PM
0331MARINE's Avatar
0331MARINE
From: You know your drunk when you swerve to miss the tree then you realize its your air freshener! Covington Ga
http://ls1howto.com/index.php?article=1
Old Jun 6, 2010 | 03:33 PM
Patches's Avatar
Patches
Heads/cam how-to but you can do the heads portion without doing the cam.
Old Jun 6, 2010 | 04:08 PM
Blue 92's Avatar
Blue 92
CI 3-4, 8-9-10 Veteran
St. Jude Donor '06-'08-'10
Readers Digest abridged version:
  1. Open hood
  2. Remove old heads
  3. Install new heads
  4. Close hood
  5. Drink
Feel free to add an additional step #5 after step #2.
Old Jun 6, 2010 | 04:29 PM
0331MARINE's Avatar
0331MARINE
  1. Open hood
  2. Remove old heads
  4. Close hood
  5. Drink
I thought step 5 was done during all the steps????
Old Jun 6, 2010 | 05:15 PM
lucky131969's Avatar
lucky131969
Old Jun 6, 2010 | 06:41 PM
Blue 92's Avatar
Blue 92
Depending on if you want the exhaust ports facing in or out.
Old Jun 6, 2010 | 07:13 PM
rr77753's Avatar
rr77753
Default After head swap
After a head swap, does the car have to be re-tuned? If so, how do you drive it to and from the tuner?
Old Jun 7, 2010 | 12:26 AM
justin_heat05
thanks guys.......does anyone else have a step by step for just the heads, to simplify the steps down?
Old Jun 7, 2010 | 09:41 AM
justin_heat05
anyone?
To Need heads swap, step by step.
