Wideband Suggestions
Old Jun 7, 2010 | 03:27 PM
dngriffi's Avatar
dngriffi
Default Wideband Suggestions
I am getting ready to order Hp Tuners Pro for my 02 Z06. I can't decide which Wideband setup to go with. Does anyone have any suggestions? NGK AFX, AEM, or Dynojet? Is there anywhere to mount the gauges besides the pillar? Thanks in advance.
Old Jun 7, 2010 | 03:49 PM
printmanjackson's Avatar
printmanjackson
St. Jude Donor '06-'07-'08-'09
NGK/AFX with the NTK sensor is the best value you can get for the money. I would tune in Lambda and not worry about that the afr gauge even says, use your software.
Old Jun 7, 2010 | 10:11 PM
HorsePowerAddicts's Avatar
0HorsePowerAddicts
Former Vendor
I use a dynojet wideband on the dyno and a AEM UEGO wideband on the street. I have no complaints about either one. Make sure you log the AFR(or lambda) on the hptuners logs.
Old Jun 8, 2010 | 08:37 AM
dngriffi's Avatar
dngriffi
Default Wideband
Thanks for your suggestions. I think I am going to go with the Dynojet Wideband 2 and the A/F gauge.
To Wideband Suggestions
