need help, door problem.
Old Jun 8, 2010 | 11:24 AM
seapup0's Avatar
seapup0
5th Gear
Default need help, door problem.
The lower hinge on my drivers side door has broken the fiberglass where it mounts to the door. This lets the door drop a little and is difficult to close. Is there a way to fix this short of a new door?
Old Jun 8, 2010 | 11:39 AM
dougbfresh's Avatar
dougbfresh
Take the door apart and fix it with a plate and reglass it.
Old Jun 8, 2010 | 12:43 PM
seapup0's Avatar
seapup0
5th Gear
doug can you give me some more detail please. Do I remove the door from the car or can it be done in place. Do I reinforce from the inside with a plate and glass on the inside also?
Old Jun 8, 2010 | 01:38 PM
dougbfresh's Avatar
dougbfresh
Without seeing the damage I can't tell you what route to take. Removing the door will make it easier to work on.
To need help, door problem.
