Spuddering under 2000 RPM
Old Jun 9, 2010 | 04:48 PM
mtlvette's Avatar
mtlvette
Originally Posted by All_Motor_C5LS6
We keep telling you what the problem may be. If you're in denial, it take less than 5 minutes to pull the MAF off and spray some MAF cleaner in there. Once you learn it's not the MAF, change your plugs and 02 sensors.
Ok will do.
Just one quick question. How wil I know if an o2 sensor is shot?
Old Jun 9, 2010 | 05:32 PM
wcsinx's Avatar
wcsinx
Originally Posted by rebelheart
You dont say how old your plugs are,often a misfire is felt under load and at low rpm.You should have a cylinder misfire in that case though.
While I don't want to be lumped into the "throw these parts at it" group, I have remedied the same symptoms on my C5 (and other cars) with a new set of plugs. And oddly enough I never saw a misfire code with my '02 when it would stumble at low RPM acceleration because of old plugs.
You're at 76k. If the plugs and wires are original, it's time anyway.
Old Jun 10, 2010 | 10:03 AM
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
Ditto. Mine were a combination of a fouled 02 and 2 fouled plugs. I changed out both and it ran normal.
Old Jun 10, 2010 | 12:25 PM
rebelheart's Avatar
rebelheart
It is a common mistake to over oil those filters and foul up your MAF.Since it started after you serviced the filter,I would start by cleaning your MAF.You can buy a spray product just for this at any parts store.
Old Jun 10, 2010 | 12:27 PM
mtlvette's Avatar
mtlvette
I did clean the MAF, that didnt help.
Old Jun 10, 2010 | 02:27 PM
All_Motor_C5LS6
Now you know what it is. 02 or plugs. 8 plugs from O'reillys $18 and 2 02s are $52/ea.
Old Jun 10, 2010 | 07:00 PM
tiojames's Avatar
tiojames
Is spuddering a combination of shuddering and sputtering?
Old Jun 13, 2010 | 08:40 PM
mtlvette's Avatar
mtlvette
Ok Guys, the problem has been fixed!!
It turns out I just had a loose spark cable.......what a stupidity!!
Old Jun 13, 2010 | 08:51 PM
lucky131969's Avatar
lucky131969
Wow..
Old Jun 13, 2010 | 08:56 PM
mtlvette's Avatar
mtlvette
I Know! i wasnt sure if I should be pissed off or relieved.
Old Jun 13, 2010 | 08:58 PM
lucky131969
Perhaps both....but you'll never get bit on that one again.
Old Jun 13, 2010 | 08:59 PM
mtlvette's Avatar
mtlvette
thats for sure!
Old Mar 14, 2011 | 01:33 PM
  #33
MickVette's Avatar
MickVette
St. Jude Donor '13
Good info. Glad to read a resolution to a problem. Helps me with a few things to check.
