I have tried to do the coolant fill procedure per the service manual:
9) Fill the cooling system through the surge tank.
10) Fill the cooling system with a 50/50 mixture of DEX-COOL® coolant and deionized water.
11) Start the engine.
12) Allow the engine to idle for 1 minute.
13) Install surge tank cap.
14) Cycle the engine RPMs from idle to 3000 in 30 second intervals until the coolant temperature reaches 99°C (210°F).
15)Shut off the engine.
16) Remove the surge tank cap.
17) Start the engine.
18) Allow the engine to Idle for 1 minute. Fill the surge tank to 12.7 mm (0.5 in) above the COLD FULL mark on the surge tank.
19) Install the surge tank cap.
20) Cycle the engine RPMs from idle to 3000 in 30 second intervals until the coolant reaches 99°C (210°F).
21) Shut off the engine.
22) Remove the surge tank cap.
23) Top off the coolant as necessary, 12.7 mm (0.5 in) above FULL COLD mark on the surge tank.
24) Rinse away any excess coolant from the engine and the engine compartment.
25) Inspect the concentration of the engine coolant.
26) Install the surge tank cap.
When I get to step 17 to start the engine again, my coolant temp is still 210ish and rising. My car never cools off enough to allow me to finish the procedure!
I have replaced the thermostat twice (OEM replacement) and the waterpump. Neither helped...
-It seems like I drained way more coolant than I have put back in but the tank is still full?
-I can pull the top radiator hose off @ the waterpump and squeeze the lower hose and coolant passes through the radiator, so I know it's not blocked.
-I can squeeze the lower radiator hose and hear/see coolant moving around in the surge tank...
-When the car gets up to 225ish my coolant tank fills itself to the brim...
I'm completely lost as to what my next step should be...
When you remove the surge tank cap, do you hear/feel pressure being vented? If not, then you need a new cap. Is the serpentine belt routed properly? Any radiator hose collapsing while running up the rpm? Are the hoses the originals? That's about all I can think of. Someone else will have more/better ideas. Good luck!
I think you have air in system. You need to vent it out. I had same problem on my 02 Trans Am. I found a very small hose near throttle body and removed it. Added coolant till it came out there. Put hose back on and added till full. That did it. Maybe someone else can answer better. Hope that helped.
There is no air bleed, he has other issues. Do a pressure test and get some test strips to see if you have any exhaust in the coolant. Either your temp sensor is wacked or you have other "issues".
When you remove the surge tank cap, do you hear/feel pressure being vented?Yes, but it seems as if the air is being sucked into the tank vs. coming out (maybe it's just me). If not, then you need a new cap. Is the serpentine belt routed properly? Yes. Any radiator hose collapsing while running up the rpm?No hose collapse. Are the hoses the originals?Yes. That's about all I can think of. Someone else will have more/better ideas. Good luck!
Dennis
Originally Posted by Old Horsepower
I think you have air in system. You need to vent it out.[I agree that I have air trapped.] I had same problem on my 02 Trans Am. I found a very small hose near throttle body and removed it.I have heard something about a hose on the throttle body, but no information to back up/justify removing it yet... Added coolant till it came out there. Put hose back on and added till full. That did it. Maybe someone else can answer better. Hope that helped.
Originally Posted by dougbfresh
There is no air bleed, he has other issues. Do a pressure test and get some test strips to see if you have any exhaust in the coolant.Can you explain this further?? Either your temp sensor is wacked or you have other "issues".
It isn't like the car just ramps up and goes into overheating. Once the car gets up to 190' it seems to take a while to get over 220. I have even watched it cool from 220 down to 214...then right back up. But, if I follow the procedure in the service manual by revving the car up, it goes up fairly quick and doesn't stop. I need to figure out a way to add more coolant because I know more came out than I have added back so far!
Not sure if it could be this simple, but I did this procedure a couple months ago. Followed it to the letter.
When I got to step 17, I was still reading the temps you are. But I went on anyway. The next step calls for eventually adding more coolant and then more cycling. After I was through with that my temps were back down again. Presumably the cold stuff I just added mixed with the hot stuff that was already in there. But anyway in my case, each time I added coolant I saw the temp drop soon afterwards and when I was done, my temps were right on the money and my coolant level exactly where it should be.
All I did when I did mine is refill it, let it run a little, drove it a little then let it cool off then toped it off. I "assume" the fans are kicking on???
I cannot drive it because it will overheat! Once I start driving it the temps will keep going till I turn it off...
Yes, both fans work properly and at the correct temps.
Then you have figure out why Do a pressure test to see if you have a LEAK internally, check with test strips like I said before-a head gasket leak can let exhaust into the cooling system causing quick overheating. You can also test the pressure cap to make sure it pops at the correct pressure. The other possibility is the temp sensor is lying. Did it overheat before you tore into it?
I guess it's time to take the car to the dealership and let them take it from there...
I don't have the equipment nor time to get much more involve...
FYI...
The dealerships use a pressure fill method... they put a vacuum on the system while they have an extra vessel for coolant... once they have the correct vacume pressure they then open a valve to the extra vessel which andhe vacume pulls THAT liquid into the car...
Its hot in Georgia... when you shut down the engine and stop the water pump... the coolant temp goes up because the internal combustion temp is much hotter than the coolant.. so the coolant in the motor gets hotter because its drawing that supper hot temp off the motor's internals and thus is harder to disipate... Some procedures are way over kill and cause more grief than their preciseness is worth..
220F is not a panic temp by any means... when the op disregarded the procedure and went with his logic, he turned on the ac which turned on the fans which drew in air to transfer heat...via the radiator.
The car then started to act normal.
