Transmission pan
Old Jun 8, 2010 | 06:00 PM
Old Horsepower's Avatar
Old Horsepower
Default Transmission pan
Looking for a transmission pan with a drain plug at bottom for my 99 C5. Stock capacity would be ok or maybe 2 extra quarts. Want to be able to change fluid in pan without having to remove it everytime.When I search all I can find are huge pans that say I will need to modify shift cable.
Thanks in advance for any help.
Old Jun 8, 2010 | 09:11 PM
Nick1's Avatar
Nick1
Try Corvette Central!
Old Jun 9, 2010 | 08:06 AM
Quicksilver Vert 01's Avatar
Quicksilver Vert 01
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16
I installed a #16C5 deep aluminum pan from this vendor: http://www.partshp.com/Pans.htm
It fits perfectly, and no modifications of any kind are required to install it.
Old Jun 9, 2010 | 12:07 PM
Old Horsepower
Thank you. Just what I was looking for!
Old Jun 9, 2010 | 12:28 PM
Quicksilver Vert 01
As a side benefit, with the cast aluminum cooling fins and the extra fluid capacity, it keeps my transmission fluid about 10 -15 degrees cooler.
The pan comes with a standard drain plug. I replaced it with a magnetic drain plug.
Old Jun 10, 2010 | 10:45 AM
Greenvette's Avatar
Greenvette
Default PATC #16C5 deep transmission fluid pan
Does this deep transmission pan requirement a different filter than the stock filter? Thanks!
Old Jun 10, 2010 | 11:14 AM
Quicksilver Vert 01
It uses the same P/N stock filter. Filter supports are cast into the bottom of the pan.
Old Jun 10, 2010 | 12:23 PM
C5Natie's Avatar
C5Natie
Ive never had to even touch the shift cable. Any pan for a 700R4, 4L60, 4L60E or 4L65E will work fine. They are all the same. Some might require a filter extension. Summit has a nice one for a good price,
http://www.summitracing.com/parts/SME-1008R/
Old Jun 10, 2010 | 12:26 PM
Quicksilver Vert 01
Originally Posted by C5Natie
Any pan for a 700R4 or 4L60E will work fine.
Not exactly true! The C5 pan requires a fill plug hole in the proper location.
To Transmission pan
