Looking for header opinions
Regarding copying designs, there is only so much room to cram 4 tubes between the engine and the frame and everything else they have to clear, they all merge into a collector, how many designs can there be...
I have also looked at going with a no cat crossover pipe and a magnaflow cat back. I figured the magnaflow will not give me much for problems as they are typically pretty good quality.
Any thoughts? This is the first vette I have worked on (its my dads car) and the install seems straigtforward for a better than average garage warrior like myself, I just have no firsthand experience with these cars or parts. Any opinions would be appreciated.
Take a look:
http://www.stainlessworks.net/cart/i...th=475_387_395
Let me know if you have any questions what so ever : )
Best regards,
...z
Time will tell.
How long before we see a flood of "My headers are cracked/leaking" posts?
But, I grew up in a time when if "Honest Charley's" didn't have it, nobody did and you made it yourself. There was instructions around on how to cut the flanges off stock headers and make your own primaries, dumping into a 4" pipe as a collector to which you welded the stock flange to connect your exhaust pipe. Or, leave them open...
Just trying to learn a few things here, every little bit helps.
Best regards,
...z
Just a quick comment on the type of material we use - Our material is basically the best 304l stainless steel that we can find and it is made here in the US. We do all of our own laser cutting in house for every single one of our flanges. Flanges are 3/8" thick 304l stainless steel.
We do make nice headers for the 2001-04 C5 applications.
1 7/8" fit really well and are available with either a catted lead pipe or an off-road pipe
Part No. C5LS103CATBT
Part No. C5LS103ORBT
