Help with rev limiters
I have an 04 with an automatic. I changed the rear to 3.42. I programmed the computer with my Predator programmer. I just changed the rear ratios. Now if I floor it the rev limiters kick in before the transmission shifts gears.
Anybody out there know what I am doing wrong with the program? I thought I just had to change the rear end settingsThanks in advance
Tom
here are a few threads that might help you out:
http://forums.corvetteforum.com/c5-s...-question.html
http://forums.corvetteforum.com/c5-s...djustment.html
http://forums.corvetteforum.com/c5-s...-settings.html
For the C5 A4, there are two values that need met in order for a WOT shift to happen; one is an RPM value, the other is a MPH value.
the non-calculator way is to place your A4 in "1" and take it to 6000rpm, noting the MPH reading on the speedo. Then program your WOT 1-2 shift to 6000 rpm... at the noted MPH - minus 1.
Next, place your A4 in "2" and take it to 6000rpm, noting the MPH reading on the speedo. Then program your 2-3 WOT shift to 6000 rpm... and at the noted MPH - minus 2.
Next, place your tranny in "3" and ... if you're brave...
Set the global rev limiter to 6200 rpm; some set it to 6400rpm.
