Active Handling Service
Old Mar 20, 2002 | 06:56 PM
REDLYNER's Avatar
REDLYNER
Default Active Handling Service
My '99 just told me to "service vehicle very soon" and "service active handling". The traction control is still good, but the active will not engage. Any advice? I would rather not pay Chevy $75 an hour if at all possible.
-Car has 36,800 miles on it
Old Mar 20, 2002 | 06:57 PM
robiferretti's Avatar
robiferretti
Default Re: Active Handling Service (REDLYNER)
i got the service active handling message once but i've not seen it since :confused:
Old Mar 20, 2002 | 07:12 PM
qs01coupe's Avatar
qs01coupe
It may be an erroneous message. I've heard going over railroad tracks will sometimes trigger that message. Reset the codes and see if it comes back up.
Old Mar 20, 2002 | 07:16 PM
CHJ In Virginia's Avatar
CHJ In Virginia
About the only thing you can do is try to borrow a scan tool or read the trouble codes from the DIC on the problems that you are having. Once you know the codes, you can identify with the service manual what the problems are. They might be minor IE: a sensor gone bad or something major. NO way to know without code analysis. MIght be something you can easily fix or might be a dealer item. Hope that this helps.
Old Mar 20, 2002 | 08:27 PM
01Pewter's Avatar
01Pewter
CI 2-3-4-5-6-7-8-9-10 Vet
CI-X Auto-X Champ (street tires)
Cruise-In IX AutoX Winner
I had that message occur when the steering wheel position sensor was failing. It took 4 trips to the dealership to fix it. There might be a Technical Service Bullitin on this problem. Hope you have better luck.
[Modified by 01Pewter, 6:35 PM 3/20/2002]
To Active Handling Service
