Blinking turn signal problem
Old Jun 11, 2010 | 10:16 PM
OTCHU's Avatar
OTCHU
8th Gear
Default Blinking turn signal problem
Hello everybody
I do my story short but I got a corvette C5 convertible few weeks ago and somebody hurt the car in the back after 6 days !! My car did go to a body shop and after 4 weeks !!!!!!, I got it back today .....
I am not very happy about the job. The paint is perfect but the bumper is not exactly in line with the both side of the car. The trunk is a little bit down from the bumper (so hard to open it with your finger). The guy said to give the car back next week so we will see.
But I just saw that my turn signal are blinking very fast .... the light are turning on right but very fast. When I push the warning light, the blinking speed is ok. Somebody have an idea ?????
Vincent
PS: Sorry about my mistakes in english (I am french)
Old Jun 12, 2010 | 07:39 AM
rws.1's Avatar
rws.1
IS the problem on one side or both?
Hyper flash can happen for several reasons..
2 of the most common are...
1 a bulb on the affected side is burned out... ie check the front bulbs
2.the previous owner installed LED light bulbs....
Old Jun 12, 2010 | 09:10 PM
flynhi's Avatar
flynhi
also check for corrision in the socket of the side blinking fast.
Old Jun 12, 2010 | 10:56 PM
OTCHU's Avatar
OTCHU
8th Gear
what do you mean flynhi ?
I did check today n every single light are working .... again only the turn signal are blinking fast and the warning signal is fine
Is it possible that the body shop did put wrong the connector ? Or do the corvette have more than one bulb for each turn signal ?
Old Jun 12, 2010 | 11:05 PM
flynhi's Avatar
flynhi
I was referring to a problem that I had with one blinker - the socket was corroded.
If you have fast blinking L and R, I have no suggestions.
Old Jun 12, 2010 | 11:20 PM
OTCHU's Avatar
OTCHU
8th Gear
yes both of them .... n that happen since I have the accident and the body shop change the bumper
To Blinking turn signal problem
