sway bars/ end link question
Old Jun 12, 2010 | 10:00 AM
jellis's Avatar
jellis
Default sway bars/ end link question
i ordered a set of sway bars from Gene but i only bought 2 end links, should i put them on the front or rear for now until i get the other 2 ordered and delivered??
i goofed it up, i know..
Old Jun 12, 2010 | 10:12 AM
edusmc1's Avatar
edusmc1
Default End Links
I would put them up front, you will feel the biggest difference up front and the rear are easyer to put on when they come in!! good luck..
Old Jun 12, 2010 | 10:16 AM
jellis's Avatar
jellis
thanks, that is what i was thinking, i just got the front off so i'll throw em up front for sure.
thanks for the advice Ed.
Old Jun 12, 2010 | 10:22 AM
ALVETTE00's Avatar
ALVETTE00
Old Jun 12, 2010 | 11:42 AM
jellis's Avatar
jellis
got it all finished up, front and rear.
now time for a test ride!! YEEHAW
Old Jun 12, 2010 | 01:50 PM
edusmc1's Avatar
edusmc1
Default Up grades
I just did mine two days ago, I put the z51 bars up front and rear with the medal end links, along with the 2010 Z06 shocks all the way around, and just a added touch I put the performance drilled and slotted rotors on. It's like night and day the difference in the responce, and the braking is real nice too.
Hope your test ride is a good one for you... Take care
ED
Old Jun 12, 2010 | 04:05 PM
Chicago1's Avatar
Chicago1
I know this is late but when I did the C6Z51 set up with the poly bushing I did the metal end links up front only.It's been like that for awhile now. I will get the rears eventually but haven't.
Old Jun 12, 2010 | 04:40 PM
jellis's Avatar
jellis
the car feels alot better, the body roll seems to be minimized and i will order the end links for the rear on monday.
Old Jun 12, 2010 | 04:49 PM
socalman's Avatar
socalman
St. Jude Donor '10
after you put the endlinks on, check the sway for clearance between the bar and rear cradle. a lot of us had the bar touching the cradle, not allowing the bar to roll as required.
To sway bars/ end link question
