Oil Temp Sensor Part Number?
Jun 12, 2010 | 05:03 PM
Does anyone have the part number for the oil temperature sensor for a 2002 C5?
Jun 13, 2010 | 12:23 AM
St. Jude Donor '12-'13-'14-'15
This should be it:
Very easy fix with a 19mm deep socket. sensor GM# 12608814
Jun 13, 2010 | 12:40 PM
Perfect! Thanks for taking the time to respond.
Jun 16, 2010 | 10:19 PM
Premium Supporting Vendor
I do not think that is proper, but I am not in the office, so if you'd like to place an order give me a call and I would be happy to help you.
Jun 17, 2010 | 07:49 AM
Ok, I'll call. I already ordered it from you on Tuesday evening.
Quote:
Originally Posted by
Gene Culley
Jun 17, 2010 | 08:40 AM
I just called and was told that the part number is correct.
Jun 18, 2010 | 12:23 AM
I had to change mine a few weeks ago, low oil temp on display. I was expecting it to have two bolts that connect it, but the bolts hold the housing that the sensor screws into. No need to drain oil, just unplug wiring harness, 19mm deepsocket to remove old and install new,plug in wiring harness. It has thread compound it allready. I think this is the same part number as the coolant sensor, I remember reading something researching the part #.
Jun 18, 2010 | 09:13 PM
7LitreC5
Sorry about that. I didn't realized you called, lol.
1994 ,
2002 ,
c4 ,
c5 ,
corvette ,
engine ,
gm ,
low ,
number ,
oil ,
part ,
replacing ,
sensor ,
temp ,
temperature ,
thread
