Right front running light socket problem
Old Jun 13, 2010 | 03:36 AM
GettnBetter's Avatar
GettnBetter
Default Right front running light socket problem
My right front running light/turn signal socket has been a problem for a while now. I've massaged it for several years but I'm tired of bending and sanding the contacts only to find it failing after a month or two. It constantly destroys bulbs by sparking, destroying the wire on the bulb. It's only the right socket, the left is fine. Is there a replacement socket I can buy to replace it?
On a side note, I'd also like to replace the bulbs with LED's, is there a decent site that sells fairly priced LED replacement bulbs and LED compatible relays so the turn signals won't blink 2x too fast when the bulbs aren't actually dead?
Old Jun 13, 2010 | 11:26 AM
byronhunter's Avatar
byronhunter
You can get the socket at Advance.
