From stock LS1 engine to Z06 engine.
Old Jun 16, 2010 | 05:20 PM
mr songman's Avatar
mr songman
That sounds like a great set-up. Where did you get that cam? Do You got the item nr for it?
Old Jun 16, 2010 | 07:10 PM
Bluefire's Avatar
Bluefire
It is a Comp Cam. This was a custom grind requested and ordered by my builder/tuner.
Old Jun 16, 2010 | 08:06 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Originally Posted by Gooser
You will need a tune for sure since the ECM and old engine with the procharger was probably tuned for boost. Other than that, should be plug and play. Loose the intercooler for NA though. The LS6 will be noticeably stronger than the LS1...especially above 4k RPM.
How much driving does it take to make ones intercooler LOOSE?
