Rear Swaybar Upside down
Jun 14, 2010 | 09:55 AM
I think my rear sway bar was installed upside down. What are the side affects of the rear sway bar being installed upside down?
Jun 14, 2010 | 11:07 AM
Well on my car it would be hitting the exhaust pipes and the ABS mount.
Jun 14, 2010 | 11:43 AM
It looks very close to the exhuast pipes
Jun 14, 2010 | 11:57 AM
Jun 14, 2010 | 12:07 PM
Can you even install it backwards? Anyways this is what it SHOULD look like
Jun 14, 2010 | 12:48 PM
Thanks, mine is definately upside down. Am I in any danger with it being upside down?
Jun 14, 2010 | 12:55 PM
Quote:
Originally Posted by
All_Motor_C5LS6
I wouldn't take sharps turns at high speeds. Just put it the right way it will take more time to lift and secure the car then to fix it.
Jun 14, 2010 | 01:06 PM
St. Jude Donor '10
Must've tweaked the crap out of the endlinks- should look at them, probably replace
Jun 14, 2010 | 01:43 PM
socalman
I dought that the endlinks have alot of room to play but it is a good time to upgrade to the metal ones though.
Jun 14, 2010 | 02:06 PM
pretty easy job to flip it over -- I see you are in Katy - pm me if you need a hand.
Jun 14, 2010 | 02:58 PM
St. Jude Donor '08-'09-'10
If the bar ends are below the lower control arms it is upside down.
