Cooling fan removal?
Old Jun 14, 2010 | 07:23 PM
Texas Dave's Avatar
Texas Dave
Default Cooling fan removal?
I've tried searching, but I don't think I'm finding what I'm looking for.
My right cooling fan on the radiator has seized up. Is there an easy way to remove it or get in there to see if something is caught in it before I order a new motor?
Only thing I found so far seems to require lifting the car and removing the whole assembly from underneath, is that correct?
Thanks.
Old Jun 14, 2010 | 09:02 PM
Pumba's Avatar
Pumba
Thanks.
No.
The cooling fan assembly is removed from the top. First you remove your air bridge and MAF.
Then you drain your coolant.
Next you remove the upper and lower radiator hose connections from the radiator.
Then you remove the coolant revervoir hose and the throttle body heating hose from the radiator.
Next, you remove the radiator cover.
Then you disconnect the plastic loops that retain the wiring harnesses around the fan assembly.
Next, you disconnect the two fan motor connectors.
Finally, you lift the fan assembly upward from the back of the radiator and out of your Corvette.
While you have it out, I would recommend that you replace the entire assembly with one of DeWitts high-output fan assemblies - http://www.dewitts.com/pages/product...asp?ProdID=378.
The DeWitts fan assembly will flow significantly more air and seeing you live in Texas, help keep your engine cooler.
In fact, while you are at it, you should consider a DeWitts Direct Fit radiator - http://www.dewitts.com/pages/product...asp?ProdID=343 if you have an automatic
or
http://www.dewitts.com/pages/product...asp?ProdID=320 if you have a six-speed.
Good luck in your decision.
Old Jun 15, 2010 | 05:42 PM
Texas Dave's Avatar
Texas Dave
Thanks. I was able to get the fan assembly out, and sure enough there was some debris stuck in the fan. Cleared it out and its running fine now.
Old Jun 15, 2010 | 07:23 PM
Pumba's Avatar
Pumba
Originally Posted by 8VETTE7
Time for a screen across the bottom of the air intake to prevent that from happening again.
http://forums.corvetteforum.com/c5-g...ve-screen.html
It's also time for some Aluminum duct tape across the bottom of the Radiator and the Air Conditioning Condenser. Leaves and other debris and be sucked up in the space between the two.
Good luck with your Vette.
Old Jun 18, 2024 | 11:49 AM
ABN C5's Avatar
ABN C5
Is it possible to remove the fan assembly without draining the coolant?
Old Jun 18, 2024 | 04:15 PM
captain vette's Avatar
captain vette
absolutely you can easily do it from under
To Cooling fan removal?
