POWERLOADER II vs LS1-Edit
Old Mar 21, 2002 | 09:35 AM
YO-EL's Avatar
YO-EL
Default POWERLOADER II vs LS1-Edit
Is there ANY way to find out what the program is or how the parameters are set in your PLII?
I was wondering if they could be found out, maybe the LS-1 edit could tweek even more. But one would need to know just exactly what the PLII is doing.
I don't want to get the LS-1 edit, only for it to "mimmick" the PLII.
Anyone?????
Thanks.
Old Mar 21, 2002 | 09:57 AM
chuckster's Avatar
chuckster
Default Re: POWERLOADER II vs LS1-Edit (indypace78)
If you copy the PL image into LS1-Edit you can then compare the parameters to a Stock Image. Download the LS1-Edit manual. You will see the Menu's are very intuitive.
Old Mar 21, 2002 | 01:31 PM
ToplessTexan's Avatar
ToplessTexan
Cruise-In II Veteran
Assuming you can read the flash you'll be able to see the intersection of the TTS tuning and what LS1-Edit provides access to, i.e. if Steve has modified tables or parameters you can't (yet) access via LS1-Edit you won't be able to see or change them. Here's a thread that may give you a better feel for what this might mean this:
http://www.ls1tech.com/ubb/cgi-bin/u...;f=23;t=000408
Only the programmer part of LS1-Edit is like the PL. The PL comes with one tune. The LS1-Edit editor allows you to roll your own, starting with whatever tune you currently have.
[Modified by ToplessTexan, 11:34 AM 3/21/2002]
Old Mar 21, 2002 | 08:52 PM
ScreaminDemon's Avatar
ScreaminDemon
I have been pretty amazed with LS1_Edit so far. I finally feel like I have control. Plus, they have a supporting forum. It's still alot to learn.
To POWERLOADER II vs LS1-Edit
