Clutch Not Disengaging
Old Jun 16, 2010 | 08:04 PM
smittydog's Avatar
smittydog
Default Clutch Not Disengaging
I've got a mild performance clutch and hydraulics that are a little over a year old and acting funny. Clutch won't disengage when the RPMs get above 4,000 RPM. Clutch worked fine for about a year and now the RPM you can disengage the clutch is getting lower. I checked the tranny fluid and bled the clutch. I'll be pulling it out in a couple of weeks and trying to figure out what to anticipate fixing. If the slave cylinder wasn't moving it's full stoke, wouldn't it lose fluid and why would hydraulics be related to RPM?
Old Jun 16, 2010 | 09:19 PM
k0ts's Avatar
k0ts
I'm going to take a wild guess and say clutch master... It's not pumping a full load of
fluid all the time.. I think you're right on the slave and it not leaking..
Old Jun 17, 2010 | 06:52 AM
smittydog's Avatar
smittydog
Any way to test the master cylinder? Hate throwing $ at stuff but don't like pulling drivetrain on C5s much either. The master is the only thing that is easy to replace in this whole assembly.
To Clutch Not Disengaging
