Odd unused plug inside driver side door panel
Old Jun 18, 2010 | 03:05 PM
Zehner189's Avatar
Zehner189
Default Odd unused plug inside driver side door panel
I pulled the driver side door panel off today to check for a wire fault. When I pulled the panel I saw a plug that was not plugged to anything. Even had it's own little clip holding it against the door. Was wondering what that is for?
Old Jun 18, 2010 | 03:19 PM
GreenDream's Avatar
GreenDream
They use the same wiring harness for every car. Depending upon which options you do or do not have, it probably would go to a different speaker system or mirrors or seat memory.
Old Jun 18, 2010 | 03:57 PM
Zehner189's Avatar
Zehner189
I'm betting it has to do with the memory option. My car didn't come with it. But I'm better that if I buy the module part that goes in the door with the mem buttons on it that it will work. If anyone else knows please let me know.
To Odd unused plug inside driver side door panel
