EBCM repair
Old Jun 18, 2010 | 07:38 PM
wadethompson1's Avatar
wadethompson1
Default EBCM repair
Does anyone know how to repair an EBCM? I know absfixer can do it but i think we can too. Is it just broken solder?
Old Jun 18, 2010 | 11:52 PM
C54ever's Avatar
C54ever
Check this out. Post #19 shows EBCM taken apart. If you get it apart just look for the bad solder joints on the relay and solder them up. http://forums.corvetteforum.com/c5-t...ht=ebcm+repair. This post also gives the part number for a new relay if you need one.
I had one bad joint and soldered it up and it worked ! I have 2001, some earlier models can't be fixed like this so if you have pre 2001 i think you're out of luck as far as repairing. Just do search and you will find a lot of info on the forums.
