Just installed headers/exhaust now backfiring
Old Jun 19, 2010 | 12:31 AM
wormser8512's Avatar
wormser8512
Default Just installed headers/exhaust now backfiring
I just installed dynatech headers/high flow cats and corsa pace exhaust two weeks ago. Car was running great. Suddenly today my car is backfiring if i downshift and my rpm's get too low (1500). Also, when standing at idle if I rev engine the response is not fast. There seems to be a delay from when I push throttle and rpm's increase. what can it be? I also have diablo tuner, kn cold air intake.
Thanks in advance,
worm
Old Jun 19, 2010 | 12:37 AM
lucky131969's Avatar
lucky131969
Thanks in advance,
worm
..you know the routine..pull your codes:
http://www.c5forum.com/ayc/dtcdic.php
Have you check the security of the plug wires? Have you inspected the O2 wiring to see if it is damaged from heat?
Old Jun 19, 2010 | 12:40 AM
wormser8512
Forgot to post that. No codes. I was suprised. Did not do the other things though. Good start.
Old Jun 19, 2010 | 12:53 AM
lucky131969
Check all exhaust connections as, air entering the exhaust stream will cause this as well.
Old Jun 19, 2010 | 01:35 AM
-DLS-'s Avatar
-DLS-
Is it a pop when you let off gas.
If so, thats not a backfire, thats an amazing sound stopped by stock exhausts.
Old Jun 19, 2010 | 04:23 AM
Blown 346's Avatar
Blown 346
Check your plug wires. My Z used to slowly burn thru them on both sides of the engine bay at the rear. I ended up having to get some Sleeves to keep the wires from burning.
To Just installed headers/exhaust now backfiring
