fuse
Old Jun 23, 2010 | 01:08 PM
976booboo's Avatar
976booboo
Default Interior lights wont work.
Can anyone help me find the fuse for the lights inside my 2000 vette. Im about to take my lunch and dont have to much time i need to replace it. This morning i was changing out the map lights in the mirror to led lights and i think i blow the fuse by one side of the wire touched the other side inside the mirror. Not the wire the metal thing that holds the bulb came out and touched other side.
Old Jun 23, 2010 | 01:24 PM
lucky131969's Avatar
lucky131969
check minifuse #2 in the passenger footwell.
Old Jun 23, 2010 | 01:31 PM
976booboo's Avatar
976booboo
will do thanks
Old Jun 23, 2010 | 10:47 PM
976booboo's Avatar
976booboo
fuse # 2 wasnt blown. I kept looking but couldnt find any fuse blown. Is there anything else or am i missing something?
Old Jun 23, 2010 | 11:23 PM
976booboo's Avatar
976booboo
anyone?
Old Jun 24, 2010 | 02:37 AM
lucky131969
You can check minifuse #6, but you'd lose the tail lamps as well if that was blown. Also check minifuse #29. If all else fails, remove the led's.
Old Jun 24, 2010 | 04:15 AM
976booboo's Avatar
976booboo
i did check #6, hell i think i checked all the mini fuses. Ill double check on # 29 If the fuses are not out then what could it be? I did put the old bulb in the map lights but still nothing.
Old Jun 25, 2010 | 12:04 AM
976booboo's Avatar
976booboo
I guess i did miss #29 mini fuse. Thanks alot lucky131969 for all your help changed the blown fuse and everything is back in order.
Old Jun 25, 2010 | 12:06 AM
lucky131969
To fuse
