gas tank noise???
Old Jun 24, 2010 | 05:50 AM
ALLRRED's Avatar
ALLRRED
6th Gear
Default gas tank noise???
I have a humming or high pitch sound that seams like it is comming from the gas tank could this be the fuel pump or sending unit? If so how do I get to it to change it? If I don't fix it for a while what problems could it cause? thanks for any info
Old Jun 24, 2010 | 07:43 AM
LisaJohn's Avatar
LisaJohn
St. Jude Donor '10
Yep! I turn up the music or take the top off!
L
Old Jun 24, 2010 | 09:11 AM
rebelheart's Avatar
rebelheart
You are hearing the high pressure electric fuel pump inside your tank,hard to say if it is normal from here!
To gas tank noise???
