Converting to LS7
Old Jun 24, 2010 | 10:53 AM
LT70ZR91's Avatar
LT70ZR91
Default Converting to LS7
Going to replace a stock LS1 and with an LS7 (24 tooth reluctor) with all of the goodies, cam, ported heads, PTB, ported intake, Kooks, 100 mm mass air sensor, etc. What do I need to do for a starting spot for tuning. I know that the Halltech mass air sensor requires a change in programming when added to a stock LS7 but this ecm will have a stock LS1 tune to start.
Please educate me!!!
Old Jun 24, 2010 | 11:20 AM
lucky131969's Avatar
lucky131969
check the scan & tune section as well.
Old Jun 24, 2010 | 11:48 AM
bcseitz's Avatar
bcseitz
This will obviously not be a stock LS7. With a cam, head, maf ect. change you will need , from scratch, a custom tune. You could try a mail order tune to start with from an experienced tuner like Charlie Williams then tweek the tune from there. Or just trailer it to a tuner when you get everything installed.
That 427 should be a world of difference from your old LS1!
Hope all goes well for you!
Old Jun 24, 2010 | 01:56 PM
99FRC Newb's Avatar
99FRC Newb
as long as you are in Illinois, give Larry at Speed Inc a call.
866-571-SPEED
i've been talking to them about an LS7 setup recently
Old Jun 25, 2010 | 12:44 PM
David426's Avatar
David426
I'm wondering how much added weight this will give the car.. paticularly on the front/rear weight ratio for handling purposes..
Old Jun 25, 2010 | 01:04 PM
LT70ZR91's Avatar
LT70ZR91
I don't think that there is that much of a difference in wieght between the LS1 and LS7. I am going to use a wet sump system so there will not be a dry sump tank. I know that the C5R Block is about 10 lbs heavier but that is not any big thing. It should be real close.
Old Jun 25, 2010 | 01:18 PM
Nd4spd2's Avatar
Nd4spd2
St. Jude Donor '08
866-571-SPEED
They just tuned my 2000 FRC after cam/header install and did a good job.
To Converting to LS7
