I need help MAF trouble!!!
Old Jun 25, 2010 | 07:07 PM
jetstreamC5's Avatar
jetstreamC5
Default I need help MAF trouble!!!
Ok I got in my 99 A4 Coupe yesterday and it starts up runs fine pi it in gear move 2 feet and it dies you can rev it do what ever but as soon as you put it in gear and it starts moving it dies so today I pulled the code and says MAF or VAF A circuit low input. What do you guys recommend I do?
Old Jun 25, 2010 | 07:11 PM
dougbfresh's Avatar
dougbfresh
The security system will cut off the fuel @ 2mph, maybe that's your problem-have another key to try? Is the security light on???
Old Jun 25, 2010 | 07:22 PM
jetstreamC5
The security light flashes when you put the key in before you turn it on but it did show up on my display pull key wait 10 sec.
Old Jun 25, 2010 | 09:59 PM
jetstreamC5
Anyone else got any suggestions or know how to go about fixing it?
Old Jun 25, 2010 | 10:39 PM
lucky131969's Avatar
lucky131969
Post your codes.
Old Jun 25, 2010 | 11:16 PM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
It's your key. If you have another key try it. The resistor on your key is probley going. You can have a tuner disable that feature.
jetstreamC5
Originally Posted by lucky131969
Post your codes.
My buddy pulled them for me I'm not sure what the actual code number was but he said it said MAF or VAF A circuit low input
Old Jun 25, 2010 | 11:23 PM
jetstreamC5
Ok I don't have a spear so do I just have to buy a new key from the dealership or can the dealership disable it?
Old Jun 25, 2010 | 11:28 PM
Wicked C5's Avatar
Wicked C5
St. Jude Donor '04
Dealer won't disable it. Do a search some people have had success with cleaning. Do a search. A tuner with Hp tuners can disable. I have mine disabled.
Old Jun 25, 2010 | 11:32 PM
jetstreamC5
Thanks for the help.
Old Jun 25, 2010 | 11:50 PM
lucky131969
http://www.c5forum.com/ayc/dtcdic.php
Old Jun 26, 2010 | 06:08 AM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
You don't have column lock do you?
Old Jun 26, 2010 | 01:57 PM
jetstreamC5
Yeah it started showing service column lock.
To I need help MAF trouble!!!
