***[WARNING] BROKEN SUSPENSION!!***
Old Mar 22, 2002 | 10:42 AM
Steve Straus's Avatar
Steve Straus
Default Re: ***[WARNING] BROKEN SUSPENSION!!*** (BatMobile)
No kidding, why are you trying to fix this yourself? I think the General has some 'splainin to do!
Old Mar 22, 2002 | 10:44 AM
BatMobile's Avatar
BatMobile
Tropical Moderator
Cruise-In 1-5 Veteran
St. Jude Donor '03-'04-'10-'11
Default Re: ***[WARNING] BROKEN SUSPENSION!!*** (Steve Straus)
NO DEALER...NO WARRANTY...
Just got to do what needs to be done to get it fixed...
Neill
Old Mar 22, 2002 | 10:48 AM
theanswriz42's Avatar
theanswriz42
Cruise-In 8 & 10 Veteran
St. Jude Donor '08, '15
I'd get that sucker on a boat to Florida and get a dealer to fix it. That should not be happening with a C5, let alone any 2 year old car.
:cheers:
Old Mar 22, 2002 | 11:14 AM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
i would contact GM about this because this could be a quality control issue they would have to deal with because there could be other C-5s with the same problem. check with adam boca at NCM as he may know who to contact at the factory. :chevy
Old Mar 22, 2002 | 11:20 AM
adam12's Avatar
adam12
Default Re: ***[WARNING] BROKEN SUSPENSION!!*** (clem zahrobsky)
At least you didn't get hurt when it happened.
Old Mar 22, 2002 | 11:35 AM
2manycars's Avatar
2manycars
From: I know when the doggie he piss onna ma leg...
Cruise-In IV Veteran
St. Jude Donor '14
:eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek:
HOLY COW!!! Looks like my guesses were close. I would have expected a mount on the lower A-arm to fail before one of the uppers, though. Glad that the car didn't hurt you or anyone else! Find the most competent welder on that island and have them TIG weld it for you. Have them check the rest of the mounts on the frame while they're at it, especially the other mount on that arm. Better to catch any developing problems now, plus you'll feel better about the car. Too bad you're not in Jersey, I know a guy who can fix that in a snap, and it'd be better than any welds GM ever did! Best of luck with the repairs! Give her a nice relaxing Zaino rub when she's done. And OK, no wisecracks about the wheelwells. ;) (read about my fanaticism here... http://forums.corvetteforum.com/zerothread?id=261774 )
Hope you're back on the road real soon!! :cheers: :cheers: :cheers:
Old Mar 22, 2002 | 11:50 AM
aces's Avatar
aces
Default Re: ***[WARNING] BROKEN SUSPENSION!!*** (SloRvette)
DO NOT STICK WELD THE BRACKET. The rear frame section on the car is a High Strength Low Alloy steel. Stick welding will put too much heat into the area weakening the steel at the intersection of the heat affected zone (red hot heat basicly turns HSLA steel into mild steel by changing the grain structure). Proper weld in the area is MIG as recommmended by GM. TIG welding would also be proper. The frame rail and the bracket are both basicly a thick guage sheet metal. A 175 amp MIG welder can blow holes in it. Clean the area throughly grind off any remaining weld on both the frame and the bracket and reweld. Then have the car realigned. Have you got a dealer there ? That should be a warranty issue.
I was gonna say TIG . If you MIG , don't use a pocket MIG. Use the regular size one. :eek: :eek: :eek:
Old Mar 22, 2002 | 12:15 PM
Zee Freak's Avatar
Zee Freak
St. Jude Donor '03-'05-'06
Before you weld on that car be sure to properly unhook your computers. Otherwise as soon a you start to weld on the car you will fry them. Ask your nearest dealers service department or contact Chevy. :yesnod:
Old Mar 22, 2002 | 12:23 PM
bowtieguy's Avatar
bowtieguy
I don't have a C5, but a 2000 Z28 and I had the left spring perch weld break on the left rear(after 20K mi.). The local dealer would not warranty it. They told me that because I had swapped the pan-hard rod out, that was the cause. :bs They wanted to install a whole new rear-end, :eek: luckly the tech that found the problem told me that I could just get it re-welded and save $2K.
Even though the cars are manufactured in different plants I found this to be a little weird. :eek:
I ended up getting it re-welded at a shop where the guy works on a lot of GM cars, and he happened to have a 2000 Z28 on the rack. And the weld on that car was perfect, the one that was on mine was just a few tack welds. :mad
Good luck on getting yours fixed though, hopefully you have getter luck than me
Old Mar 22, 2002 | 12:55 PM
2manycars's Avatar
2manycars
St. Jude Donor '14
Default Re: ***[WARNING] BROKEN SUSPENSION!!*** (bowtieguy)
That really makes me think. My car is still up on stands from my fanatical cleaning rampage, so I'm gonna go around it again tonight and scrutinize the welds on those A-arm perches. :yesnod:
Old Mar 22, 2002 | 01:08 PM
BatMobile's Avatar
BatMobile
Tropical Moderator
I saw Adam online this morning, he has the link and pics and was going to get in touch with someone at the factory...
Hopefully something GOOD will come out of all this.
:rolleyes:
Neill
Old Mar 22, 2002 | 02:08 PM
scorp508's Avatar
scorp508
:nonod: Lets just hope your car was a freak with a weak weld in combo to being driven where it is.
Old Mar 22, 2002 | 02:26 PM
  #33
TTRotary's Avatar
TTRotary
Default Re: (scorp508)
I can't believe people are recommending re-welding the bracket. This is not a tractor. This is a 2 year old car, which NEEDS TO GO BACK TO GM, so they can x-ray the metal and figure this out. If you re-weld it, the factory will never figure out what went wrong in the first place, and that needs to happen.
Remember the PINTO? This is in the same category. Plus, if you ever sell the car, you may be putting someone else's life in danger. Sorry to sound like a panzie, but this is where consumer rights matter. GM screwed up, let them fix it, at their expense. Maybe you'll even get a new car out of this... If it were me, I'd already have a lawyer handy.
I know where I'll be spending my evening...under the car with a flashlight. CRAP :mad :mad :mad
[Modified by TTRotary, 12:27 PM 3/22/2002]
Old Mar 22, 2002 | 03:10 PM
  #34
BatMobile's Avatar
BatMobile
Tropical Moderator
Default Re: (TTRotary)
Thanks for the concern...
The part is a simple bracket, welded to the frame in the first place. The bracket itself appears to be fine and the frame for sure is fine. I'm about to go pull everything apart in a few minutes, but I suspect that once everything gets cleaned up that both the frame and the bracket will be in the same as new condition as when the factory had them before they did the weld. My guess is something went amiss in the weld and the weld itself just failed.
I am already in talks with a GM rep at the moment and the pics and details are flying around their offices...
:cool:
Neill
Old Mar 22, 2002 | 04:35 PM
  #35
BatMobile's Avatar
BatMobile
Tropical Moderator
Downloading some new pics now...
Not good...
The frame rail appears to be cracked...
:mad
Neill
Old Mar 22, 2002 | 04:55 PM
  #36
2manycars's Avatar
2manycars
St. Jude Donor '14
:eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek: :eek:
What the heck is going on here???
Old Mar 22, 2002 | 05:03 PM
  #37
Untouchable00's Avatar
Untouchable00
Default Re: ***[WARNING] BROKEN SUSPENSION!!*** (mrkln)
Did you hit anything makor recently??? That is crazy!!!
To ***[WARNING] BROKEN SUSPENSION!!***
Old Mar 22, 2002 | 05:19 PM
  #38
BatMobile's Avatar
BatMobile
Tropical Moderator
Default Re: ***[WARNING] BROKEN SUSPENSION!!*** (Untouchable00)
No...that is what is so crazy.
If I smacked something hard, I could understand and ALMOST excuse it...
but NOPE!
Neill
Old Mar 22, 2002 | 05:57 PM
  #39
davette's Avatar
davette
Please keep us updated. This might have implications for every C5 out on the road. :eek:
Old Mar 22, 2002 | 07:28 PM
  #40
TTRotary's Avatar
TTRotary
Default Re: ***[WARNING] BROKEN SUSPENSION!!*** (davette)
You bet. I'm thinking that what we have here is the first instance of a frame failure on the C5 chassis. Why Bat? Because of where the car is located. I don't think the roads are to be blamed (even though I know what Bat means having been to the USVI many times). What I do think accelerated the failure process is the extremely corrosive air in which the car is continually bathed. You've got heat, high humidity, and salt air.
Not a problem with a good clean weld, but a problem on a weak spot weld or tack weld. This being an automated production process, I would expect other failures to occur on older cars over time...maybe in a couple of years...or maybe in a couple of months. The scary part is that the upper control arm mount does not bear significantly high loads. But the upper shock mount does. Those who have mounted coilovers should think about this very carefully. Luckily, the lower control arms and rear subframe are forged alloy. Let's hope the subframe brackets have decent welds :eek: :eek: :eek:
Bat, did the crack occur on a hydroformed (non-welded) part of the frame, or did it occur on any of the reinforcement plates that have been welded to the frame in various places? I wonder what came first...the cracked mount or the cracked frame. the two are obviously related. I really think this car needs to go back to GM without being touched, but of course it's not my car and I'm not there to experience your frustration. Sorry for your troubles, Bat
