Check Engine light - Code PO803HC
Old Jun 26, 2010 | 10:33 PM
GreenDream's Avatar
GreenDream
Default Check Engine light - Code PO803HC
I just started getting the Check Engine light a couple days ago. DIC shows PO803HC 1-4 Upshift Solenoid Control Circuit Manual Trans.
I clear the code and the light goes off for awhile. Today I found that if I avoid 1st gear and start out in second, the light will not come back on. As soon as I put it in 1st again, CE appears. I do have the CAGs bypass and occassionally see the 1-4 skip shift light, but it does not force me to go into 4th. I hit 2nd and the light goes out. Any ideas? Anyone ever experienced this?
Old Jun 27, 2010 | 01:36 AM
87SAM's Avatar
87SAM
Maybe your CAG's took a dump. The resistor inside has been known to fail.
Old Jun 27, 2010 | 11:46 AM
SebringSixSpeed's Avatar
SebringSixSpeed
Let me say that the by-pass resistor does not last forever. I have replaced mine 3 times. I get the same code that you get with the CEL and I know exactly what I have to do to fix it. ~ Replace the bypass resistor. After the second one I stopped buying the complete kit from vendors and just got a pack of resistors from Radio Shack and soldered one in place of the burned out one - you only have to dig out the black insulating goo in the terminal to get to it. And as a matter of fact the resistor I put in from Radio Shack has already outlasted the other two put together. The whole pack is only like a buck or two.
Old Jun 27, 2010 | 03:59 PM
GreenDream's Avatar
GreenDream
Thanks guys.. I guess if I remove the bypass and don't get the check engine light, I will know what it is.
To Check Engine light - Code PO803HC
